[mapserver-users] FastCGI, MapServer and Apache on Linux
Nicolas Chenier
nicolas.chenier at agr.gc.ca
Wed Sep 1 10:43:13 EDT 2010
Thank you Jeff!
So you mean to tell me that this old tutorial is still the baseline for
FastCGI w/ Mapserver and Apache? This was written a while back, and
seems to be specific to Apache 1.3... Does anyone know of any
modifications that need to be done for Apache httpd 2.2? Any other/new
optimizations to the fastCGI settings?
Thanks,
Nic
On Wed, 2010-09-01 at 07:48 +0200, Jeff McKenna wrote:
> On 10-08-31 9:44 PM, Nicolas Chenier wrote:
> > Good day all,
> > I am fairly new at this, and I am seeking help.
> > We are currently using a MapServer setup with Apache on Linux, supported
> > by Tilecache.
> > Due to the growing number of maps and tiles, we need to cut back on
> > caching as we are running out of disk space to store the tilecache.
> > We would like to use FastCGI to generate tiles on the fly with
> > MapServer, Apache and our SDE db connection, all running on Linux.
> > I am looking for the optimal way to get this setup, using the latest
> > Mapserver release with Apache2.
> > Is there an easy step-by-step guide on getting this setup? I have been
> > searching through the web, the mapserver wiki and mailing list without luck.
> > I am simply looking for the optimal FastCGI configuration settings,
> > along with deployment instructions from scratch... doesn't have to be
> > too detailed but just an outline of how we should proceed... Does
> > anything need to be recompiled with FastCGI support, etc etc...
> > I really appreciate the help.
> Hello,
> You will find instructions on this at:
> http://www.mapserver.org/optimization/fastcgi.html
> If, during your MapServer/FastCGI travels, you have additional notes to
> add to the documentation, it would be great if you could file a ticket
> on MapServer Trac and record your additional notes there
> (http://trac.osgeo.org/mapserver/) - if you do not have a login, create
> one at: https://www.osgeo.org/cgi-bin/ldap_create_user.py
> Happy travels.
> -jeff
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100901/64cc3f29/attachment-0001.html
