[mapserver-users] Display performance
Chris Jackson
webturtles at gmail.com
Fri Sep 3 05:54:09 EDT 2010
Jukka
Thank you for the code I will give it a go. I guess I will dust off the
field calculator in ArcMap and see if that improves things somewhat, I guess
that is a similar overhead when classifying a raster by pixel value (not
sure how to fix that). So if I understand you right then I would just use a
number per class (1-15 say) in the new attribute field and then code
something like:
CLASSITEM "MEAN_SP_PC"
CLASS
EXPRESSION "1"
NAME "> 4.00 (m/s)"
STYLE
COLOR 135 99 64
END
END
Thanks again for the insight.
Chris
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100903/0e362265/attachment.html
