[mapserver-users] Re: VRT memory usage (from C# Mapscript)
Frank Warmerdam
warmerdam at pobox.com
Fri Sep 3 11:28:52 EDT 2010
Lisa Gaudette wrote:
> Frank Warmerdam wrote:
>> Lisa,
>> In recent versions of MapServer an effort is made to keep GDAL files open
>> between render requests for raster layers with a single file as opposed
>> to a tile index. I wonder if you might be running into a problem with
>> this behavior in a long running mapscript script. I don't understand
>> the whole context in which you are operating so I could be off base. But
>> you might consider adding:
>> PROCESSING "CLOSE_CONNECTION=NORMAL"
>> to your raster layer to force the files to be closed at the end of a
>> render.
> That seems to fix it. Is there any way to set that option globally when
> compiling?
You could change this code in mapraster.c:
if( close_connection == NULL && layer->tileindex == NULL )
close_connection = "DEFER";
To assign a default of "NORMAL" instead.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
