[mapserver-users] Re: Raster Layer Error
ibrahim saricicek
ibrahimsaricicek at gmail.com
Mon Sep 6 04:55:48 PDT 2010
Hi..
No it's not about the path, I've tried shapepath either.
On Mon, Sep 6, 2010 at 12:23 PM, Sumit Sharma [via OSGeo.org] <
ml-node+5502593-320101334-10162 at n2.nabble.com<ml-node%2B5502593-320101334-10162 at n2.nabble.com>
> wrote:
> I would suggest you to revisit your path, try using shapepath, imagepath
> etc. and make sure that you are able to refer your files properly.
> You may also like to carefully observe permissions on your server. Try to
> see mapserver debug info by setting debug level 5, that may also give you
> some more information about your problem.
> -Sumit
> View message @
> http://osgeo-org.1803224.n2.nabble.com/Raster-Layer-Error-tp5502458p5502593.html
> To unsubscribe from Raster Layer Error, click here<http://osgeo-org.1803224.n2.nabble.com/template/TplServlet.jtp?tpl=unsubscribe_by_code&node=5502458&code=aWJyYWhpbXNhcmljaWNla0BnbWFpbC5jb218NTUwMjQ1OHwtMTMzMTA0MzIxNQ==>.
> Hi Hi All,
A 800Mb Jpeg2000 file works on MS4W, but returns an error on Linux.
What is meant on the error message?
*The error message is;*
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named 'Uydu'.
GetBlockRef failed at X block offset 267, Y block offset 96: Unable to
access file. GDALRasterIO() failed: drawGDAL()
</ServiceException>
*This is layer definition;*
LAYER
NAME 'Uydu'
DATA "/var/www/Turkiye.jp2"
TYPE RASTER
PROJECTION
"init=epsg:4326"
END
STATUS ON
END
This is Window 7 side;*
version 5.4.0-rc2 Libs;
curl-7.15.1
expat-2.0.1
fcgi-2.4.0
fits-3.0.2
freetype-2.1.10
fribidi-0.19.1
gd-2.0.35
gdal-1.6.0 RC2
geos-2.2.3
gettext-0.13
hdf5
jbigkit-1.6
jpeg-6b
libecwj2-3.3
libgeotiff-1.2.3
libiconv-1.9.1
libintl-0.11.5
libpng-1.2.8
libxml2-2.6.23.win32
mapserver-5.2.1
ming-0.2a
mrsid-6.0.7.1407
mysql-5.0.18-win32
netcdf-3.6.1
PDFlib-Lite-6.0.2
php-5.2.6
postgresql-8.3.3
proj-4.6.1
Python-2.5.1
regex-0.12
sqlite3
SWIG-1.3.33
tiff-cvs (02/04/08)
xerces-c-2.7.0
zlib-1.2.3
*This is Debian Lenny 64-bit server side;*
version 5.4.2 libs;
Mapserv 5.4.2
-lgd -L/usr/lib64 -lgd -ljpeg -lfreetype -lz -lpng -lz -lXpm -lX11
-L/usr/local/src/agg-2.4//src -lagg -ltiff -ljpeg -lfreetype -lz -lpng -lz
-lXpm -lX11 -lproj -ljpeg -lpng -L/usr/local/lib -lgdal -L/usr/lib -lgeos_c
-L/usr/lib -lsqlite3 -lodbc -lodbcinst -L/usr/lib -lexpat -L/usr/lib
-lxerces-c -lpthread -ljasper -lhdf5 -lmfhdf -ldf -lgif -ljpeg -ltiff -lpng
-lnetcdf -lpq -L/usr/lib -lpq -lz -lm -lrt -ldl -lcurl -L/usr/lib -lpq
-L/usr/lib/mysql -lmysqlclient -lmysqlclient -lcurl -L/usr/lib -lgeos_c
-lpthread -L -lc -lz -lxml2 -lm -lstdc++
Gd-2.0.35
Gdal 1.7.2
./configure --with-png --with-jpeg --with-gif --with-jasper=/usr/local
JasPer support: yes (GeoJP2=yes)
jasper-1.900.1.uuid
./configure
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100906/072be71e/attachment.htm>
More information about the MapServer-users
