[mapserver-users] Split Polygon using Clint or server side code
not with PostGIS
venkat
ven.tammineni at gmail.com
Tue Sep 7 04:24:49 EDT 2010
Dear Wim,
Thanks for your response.I am looking into the same.
Thanks and Regards,
Ven
On Tue, Sep 7, 2010 at 1:39 PM, Wim Vanbelle <wimvanbelle at gmail.com> wrote:
> Hmm. No guarantees, but perhaps the geoapi.net or nettopolgysuite have
> this functionality.
> Alternatively, what you could do, although it still involves a spatial
> database, is use the C# Sql Spatial libraries. You could install a
> microsoft sql server 2008 (spatial) database, reference the spatial
> libraries and perform the split of the polygon with those spatial functions,
> using C#. But as you stated, this is probably not the solution you are
> looking for.
> Maybe someone else is aware of another third party library that does this
> On 7 September 2010 08:59, venkat <ven.tammineni at gmail.com> wrote:
>> Dear Wim,
>> Thanks for your great response...I am not looking for
>> triangulation(tin).I am looking for Split operation based on line...I did it
>> using PostGIS (st_split) function.I want to work it by coding (that can be
>> client or server side code.....)..Please let me know is it possible.if it is
>> possible, please let me know..
>> Thanks and Regards,
>> Ven
>> On Tue, Sep 7, 2010 at 12:25 PM, Wim Vanbelle <wimvanbelle at gmail.com>wrote:
>>> Hi,
>>> Are you trying to split a polygon using another geo object like a line?
>>> Or do you just want to divide the polygon in smaller pieces? You may want
>>> to look at triangulation for that. Take a look here:
>>> http://en.wikipedia.org/wiki/Polygon_triangulation
>>> Best regards,
>>> Wim
>>> On 7 September 2010 07:46, venkat <ven.tammineni at gmail.com> wrote:
>>>> Dear All,
>>>> How i can split polygon by client(JavaScript code) or Server
>>>> side(C#).I have done splitting polygon using Postgis..I am not able to
>>>> understand how to split polygon by code(client or server side code.Please
>>>> let me know .Its very urgent.
>>>> I am waiting for your great response.
>>>> Thanks and Regards,
>>>> Ven
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100907/6c51014c/attachment-0001.html
