[mapserver-users] PHPMapscript, Ming & Segmentation fault.
Joseph Mamuchishvili
iam980 at gmail.com
Wed Sep 8 03:14:22 EDT 2010
Hello,
I have compiled MapServer 5.6.4 with PHPMapscript on FreeBSD 8.1.
During configuration Ming support was added.
phpinfo() returns the following:
MapScriptMapServer VersionMapServer version 5.6.4 OUTPUT=GIF OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER
SUPPORTS=GEOS INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR
INPUT=SHAPEFILEPHP MapScript Version
($Revision: 10204 $ $Date: 2010-06-02 06:57:48 -0700 (Wed, 02 Jun 2010) $)
mingMing SWF output libraryenabledVersion0.4.3
I am using the following php script (*testmap.php*):
<?php
$map = ms_newMapObj("/map/apache/htdocs/map/mapsql.map");
$image=$map->draw();
$image_url=$image->saveImage("\\tmp");
<HTML>
<HEAD>
<TITLE>Example 1: Displaying a map</TITLE>
</HEAD>
<BODY>
<br>
<IMG SRC=<?php echo $image_url; ?> >
</BODY>
</HTML>
and the contents for *mapsql.map* file is:
MAP NAME "Europe in purple"
SIZE 400 400
STATUS ON
EXTENT 478895 4615055 485900 4620056
UNITS METERS
SHAPEPATH "/home/map/SHP"
WEB
IMAGEPATH "/map/apache/htdocs/tmp/"
IMAGEURL "/tmp/"
METADATA
"wms_title" "wms_title" ##required
"wms_onlineresource" "
http://soso.freebsd.host/cg-bin/mapserv?map=/map/apache/htdocs/mapsql.map&"
"wms_srs" "EPSG:32638"
END
END
PROJECTION
"proj=utm"
"zone=38"
"ellps=WGS84"
"datum=WGS84"
"units=m"
"no_defs"
END
QUERYMAP
COLOR 0 0 255
STATUS ON
STYLE HILITE
END
LAYER
NAME "main_streets"
TOLERANCE 1
TOLERANCEUNITS meters
CONNECTIONTYPE postgis
CONNECTION "user=pgsql dbname=pgsql host=soso.freebsd.host"
TEMPLATE "../query/query_template.html"
METADATA
QUERYABLE "true"
fields 'quca_ge:ქუჩის დასახელება,gid:გიდი'
hyperlink 'quca|http://myurl.com'
searchfield "quca"
RESULT_FIELDS "quca_ge"
RESULT_HEADERS "the_geom"
END
TYPE POLYGON
STATUS ON
DATA "the_geom from main_streets"
CLASS
STYLE
COLOR 110 50 100
OUTLINECOLOR 200 200 200
END
END
END
END
*Everything works fine*, but now *i want to generate flash output*. So I
added the following block to *mapsql.map *file:
OUTPUTFORMAT
NAME swf
DRIVER "SWF"
MIMETYPE "application/x-shockwave-flash"
EXTENSION "swf"
IMAGEMODE PC256
FORMATOPTION "OUTPUT_MOVIE=SINGLE"
END
flash output is not generated and the following is appeared in apache error
log: *Segmentation fault (11).*
When trying to *launch *the testmap.php script from* the shell* the
following happens:
/php/bin/php ./testmap.php
*newSFWBitmapFillStyle: not a valid Bitmap FillStyle: 0*
Segmentation fault (core dumped)
What is the reason of this ? What am I doing wrong ?
Any suggestions or help will be appreciated.
Joseph.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100908/386ea4a2/attachment-0001.html
