[mapserver-users] PHPMapscript, Ming & Segmentation fault.
Joseph Mamuchishvili
iam980 at gmail.com
Thu Sep 9 02:46:17 EDT 2010
Hello.
Thank You for your suggestion.
I tried to display my map using the CGI directly... and got the same
segmentation fault error.
It would be very nice of You to tell me, how I may create the ticket (I mean
using which site).
Regards,
Joseph
On Wed, Sep 8, 2010 at 9:24 PM, Alan Boudreault <aboudreault at mapgears.com>wrote:
> Hi,
> I'd say that php mapscript is not the cause. Could you try to display your
> map
> using the CGI directly. If you get the same seg fault error, it would be
> good
> if you could create a ticket with a minimal test case with a mapfile and
> data
> (perhaps you could do a simple ogr2gr from postgis to shapefile).
> regards,
> Alan
> On September 8, 2010 03:14:22 am Joseph Mamuchishvili wrote:
> > Hello,
> > I have compiled MapServer 5.6.4 with PHPMapscript on FreeBSD 8.1.
> > During configuration Ming support was added.
> > phpinfo() returns the following:
> > MapScriptMapServer VersionMapServer version 5.6.4 OUTPUT=GIF OUTPUT=PNG
> > OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> > SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER
> > SUPPORTS=GEOS INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> > INPUT=SHAPEFILEPHP MapScript Version
> > ($Revision: 10204 $ $Date: 2010-06-02 06:57:48 -0700 (Wed, 02 Jun 2010)
> > mingMing SWF output libraryenabledVersion0.4.3
> > I am using the following php script (*testmap.php*):
> > <?php
> > $map = ms_newMapObj("/map/apache/htdocs/map/mapsql.map");
> > $image=$map->draw();
> > $image_url=$image->saveImage("\\tmp");
> > <HTML>
> > <HEAD>
> > <TITLE>Example 1: Displaying a map</TITLE>
> > </HEAD>
> > <BODY>
> > <br>
> > <IMG SRC=<?php echo $image_url; ?> >
> > </BODY>
> > </HTML>
> > and the contents for *mapsql.map* file is:
> > MAP NAME "Europe in purple"
> > SIZE 400 400
> > STATUS ON
> > EXTENT 478895 4615055 485900 4620056
> > UNITS METERS
> > SHAPEPATH "/home/map/SHP"
> > WEB
> > IMAGEPATH "/map/apache/htdocs/tmp/"
> > IMAGEURL "/tmp/"
> > METADATA
> > "wms_title" "wms_title" ##required
> > "wms_onlineresource" "
> http://soso.freebsd.host/cg-bin/mapserv?map=/map/apache/htdocs/mapsql.map&
> > "wms_srs" "EPSG:32638"
> > END
> > END
> > PROJECTION
> > "proj=utm"
> > "zone=38"
> > "ellps=WGS84"
> > "datum=WGS84"
> > "units=m"
> > "no_defs"
> > END
> > QUERYMAP
> > COLOR 0 0 255
> > STATUS ON
> > STYLE HILITE
> > END
> > LAYER
> > NAME "main_streets"
> > TOLERANCE 1
> > TOLERANCEUNITS meters
> > CONNECTIONTYPE postgis
> > CONNECTION "user=pgsql dbname=pgsql host=soso.freebsd.host"
> > TEMPLATE "../query/query_template.html"
> > METADATA
> > QUERYABLE "true"
> > fields 'quca_ge:ქუჩის დასახელება,gid:გიდი'
> > hyperlink 'quca|http://myurl.com'
> > searchfield "quca"
> > RESULT_FIELDS "quca_ge"
> > RESULT_HEADERS "the_geom"
> > END
> > TYPE POLYGON
> > STATUS ON
> > DATA "the_geom from main_streets"
> > CLASS
> > STYLE
> > COLOR 110 50 100
> > OUTLINECOLOR 200 200 200
> > END
> > END
> > END
> > END
> > *Everything works fine*, but now *i want to generate flash output*. So I
> > added the following block to *mapsql.map *file:
> > OUTPUTFORMAT
> > NAME swf
> > DRIVER "SWF"
> > MIMETYPE "application/x-shockwave-flash"
> > EXTENSION "swf"
> > IMAGEMODE PC256
> > FORMATOPTION "OUTPUT_MOVIE=SINGLE"
> > END
> > flash output is not generated and the following is appeared in apache
> error
> > log: *Segmentation fault (11).*
> > When trying to *launch *the testmap.php script from* the shell* the
> > following happens:
> > /php/bin/php ./testmap.php
> > *newSFWBitmapFillStyle: not a valid Bitmap FillStyle: 0*
> > Segmentation fault (core dumped)
> > What is the reason of this ? What am I doing wrong ?
> > Any suggestions or help will be appreciated.
> > Joseph.
> Alan Boudreault
> Mapgears
> http://www.mapgears.com
With Best Regards,
Joseph Alex Mamuchishvili
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100909/20391bc2/attachment-0001.html
