[mapserver-users] Expressions
    Bob Basques
    bob.b at gritechnologies.com
    Fri Sep 17 19:24:54 PDT 2010
  A first stab at seeing more than one class, might be to try and switch them around order wise,  one filter may be
overwriting the other for example.
bobb
On 9/17/2010 8:20 AM, Jay Kapalczynski wrote:
> I am using GeoMoose but feel this is more a question for Map Server.
> I am trying to sort my points by dates using the code below....I think that I can do this but not sure
> Is this a viable format "2Y%2M%2D" ?
> · As for the field in the shapefile...If I use an integer it removes the 0 from the 092110, (sept 21^st 2010)
> · If I use a date then there are "/"  ... 9/21/10
> · The only way I can see this happening is using a text field with retains the 0 in 092110
> When I use the textfield "dateValues" as seen below I can get the stars to draw but only the LASTWEEK...for some
> reason the LASTTWOWEEKS does not show  and I know that I have a few records with dates in the last 14 days...
> Thoughts?
> THANKS....all your help is very appreciated....
> Main .xml file
> <map-source name="Burglaries" type="mapserver">
> <file>./maple_grove_datasets/police/Burglaries.map</file>
> <param type="today" offset="-7" name="LASTWEEK" format="%2Y%2M%2D" />
> <param type="today" offset="-14" name="LASTTWOWEEKS" format="%2Y%2M%2D" />
> <param type="today" offset="-30" name="LASTTHIRTY" format="%2Y%2M%2D" />
> <param type="today" offset="-90" name="LASTNINTY" format="%2Y%2M%2D" />
> <layer name="Burglaries"/>
> </map-source>
> .map file
> CLASS
>        NAME 'Last Weeks'
>        EXPRESSION ('[dateValues]' > '%LASTWEEK%')
>        STYLE
>               COLOR 0 0 0
>               SYMBOL "star"
>               SIZE 12
>        END
> END
> CLASS
>        NAME 'Last Two Weeks'
>        EXPRESSION ('[dateValues]' > '%LASTTWOWEEKS%')
>        STYLE
>               COLOR 0 100 50
>               SYMBOL "star"
>               SIZE 12
>        END
> END
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100917/cd203d3a/attachment.htm>
More information about the MapServer-users
