[mapserver-users] SVG, PDF and Flash output in MapServer 6.0.
Yewondwossen Assefa
yassefa at dmsolutions.ca
Mon Sep 20 09:01:41 EDT 2010
On 10/09/2010 4:08 PM, Andreas Neumann wrote:
> Hi,
> Thank you for your information on future plans about output based on
> Cairo.
> Regarding the SVG support, my main concern is that if the output goes
> through Cairo than there is no chance of adding attributes and
> semantics to the vector features in SVG - am I correct? In SVG one
> could f.e. embed title and description elements, as well as non-graphical
That is correct from what I can see.
> attributes in a separate namespace in the XML output. Now that SVG
> support will be widespread in all browsers (IE9 will be implementing
> SVG), I would assume that people would make more use of SVG output,
> also for interactive maps. In this setup it would be nice if one could
> have the option between a pure graphical output (probably the CAIRO
> output version) and a more semantically rich output (a separate output
> driver?) I would recommend to go with Cairo, but leave the door open
> for another, alternative output driver for more sophisticated SVG output.
I agree with you that we would have more control on what we can output
if we have a native MapServer svg driver. I think adding a native SVG
driver will always possible baring in mind that there is enough
need/interest to add it and support it in the long term
Thanks for your feedback.
regards,
> Regarding SWF: it would be better if Flash would die in the long run -
> it is not part of the open web and a black box. All browser project
> now seem committed to implement SVG and canvas. So I myself wouldn't
> care if you would drop SWF support. Other users may think different.
> Just my two cents,
> Andreas
> On 9/10/10 5:09 PM, Yewondwossen Assefa wrote:
>> Hi all,
>> The Dev team is reviewing and preparing for the 6.0 MapServer
>> release [1][2]. There are significant changes and new features in
>> this release. One of them is the rendering overhaul. The reasons
>> behind is to facilitate the long term maintenance and make sure that
>> all the output formats are in sync feature-wise.
>> Currently output drivers such as svg, pdf and flash lag in
>> functionality and supported features compare to the AGG/GD output.
>> As part of this re-factoring, the Cairo library [3] will be added
>> allowing SVG and PDF outputs to pass through this library. This
>> would deprecate the current support of native svg and pdf in MapServer.
>> The other renderer that is affected is the SWF (Flash) renderer: at
>> this point there is no effort to bring this output feature to the
>> level of other renderers. This means that there is a big chance that
>> the SWF support will not be part of the 6.0 release (unless someone
>> wants to fund it). Is this something that affects lots/some users?
>> best regards,
>> [1] http://trac.osgeo.org/mapserver/wiki/60ReleasePlan
>> [2] http://trac.osgeo.org/mapserver/wiki/60MigrationIssues
>> [3] http://cairographics.org/
>> Assefa Yewondwossen
>> Software Analyst
>> Email:yassefa at dmsolutions.ca
>> http://www.dmsolutions.ca/
>> Phone: (613) 565-5056 (ext 14)
>> Fax: (613) 565-0925
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100920/2ca758ad/attachment.html
