[mapserver-users] Random color
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Wed Sep 22 19:24:40 EDT 2010
You didn't say what environment you're in. If PostGIS I suspect you could write a function to generate a random color string (either r g b or #hex) and then bind MapServer color values to the function output. The function would simply generate 3 random numbers between 1 and 255. In MapServer it'd be:
LAYER
DATA "the_geom from (select *, myColorMaker() as mycolor from myTable)
CLASS
STYLE
COLOR [mycolor]
END
END
END
I've not tried anything like this but it should work...
Steve
________________________________________
From: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] On Behalf Of Ibrahim Saricicek [ibrahimsaricicek at gmail.com]
Sent: Wednesday, September 22, 2010 7:34 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Random color
Hi list,
Can I define random colors for each of objects in a table?
Or hhould I define classes for each of them?
(I don't want to use Quantum Gis styling and mapserver export.)
Thanks in advance...
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Random-color-tp5558894p5558894.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
