[mapserver-users] reprojection
Julien Cigar
jcigar at ulb.ac.be
Tue Sep 21 15:09:10 EDT 2010
Hello,
I'm trying to re-project a RASTER layer but without success so far.
I have the following TIFF file:
mage at mordor:/home/mage/gis % gdalinfo antarctica_sthn_ocean.tiff
Driver: GTiff/GeoTIFF
Files: antarctica_sthn_ocean.tiff
Size is 12216, 9094
Coordinate System is:
PROJCS[" Projection Name = WGS_1984_Stereographic_South_Pole Units =
meters GeoTIFF Units = meters",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Polar_Stereographic"],
PARAMETER["latitude_of_origin",-71],
PARAMETER["central_meridian",0],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-8563840.575678950175643,6466755.550653258338571)
Pixel Size = (1420.390210742724321,-1420.394765779645695)
Metadata:
TIFFTAG_XRESOLUTION=900
TIFFTAG_YRESOLUTION=900
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left (-8563840.576, 6466755.551) ( 52d56'33.71"W, 8d 9'27.23"S)
Lower Left (-8563840.576,-6450314.449) (126d59'13.87"W, 8d12'36.90"S)
Upper Right ( 8787646.239, 6466755.551) ( 53d39'3.45"E, 7d12'35.07"S)
Lower Right ( 8787646.239,-6450314.449) (126d16'45.99"E, 7d15'38.97"S)
Center ( 111902.832, 8220.551) ( 85d47'54.65"E, 88d58'2.41"S)
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
Overviews: 6108x4547, 3054x2274, 1527x1137, 764x569
Metadata:
LAYER_TYPE=athematic
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
Metadata:
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
Metadata:
If I understood well the output of gdalinfo, the projection seems to be
EPSG:4326.
Now I want to re-project this to EPSG:3031.
I tried with the following MAP file :
MAP
NAME "antarctic"
STATUS ON
SIZE 600 400
EXTENT -8563840.576 -6450314.449 8787646.239 6466755.551
IMAGECOLOR 255 255 255
PROJECTION
"init=epsg:3031"
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
END
LAYER
NAME "ocean"
TYPE RASTER
STATUS DEFAULT
DATA antarctica_sthn_ocean.tiff
PROJECTION
"init=epsg:4326"
END
END
END
... but all what I get is a gray 600x400 PNG image ...
Any idea what could be the problem ?
Thanks,
Julien
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100921/5003182b/jcigar.vcf
