[mapserver-users] Different OUTPUTFORMAT options for each layer in
a mapfile
turtlewax
frankhevans at yahoo.com
Sat Sep 25 17:06:39 EDT 2010
I need to serve up NITFs through mapserver. There is an accuracy issue in the
GDAL NITF driver. Unless you specify the GEOLOB TRE, GDAL just writes
IGEOLO, which doesn't have enough decimal places for sub-meter accuracy.
Based on testing, I could tell MapServer/GDAL to write the GEOLOB (see
example below). But the location info is unique to each raster, hence the
OUTPUTFORMAT options would be different for each layer.
QUESTION:
I could store each raster in its own mapfile, so it would have its own NITF
OUTPUTFORMAT settings. Is there any other option?
OUTPUTFORMAT
NAME NITF
DRIVER "GDAL/NITF"
IMAGEMODE RGB
MIMETYPE "image/nitf"
EXTENSION "ntf"
FORMATOPTION "BLOCKXSIZE=1024"
FORMATOPTION "BLOCKYSIZE=1024"
FORMATOPTION
"TRE=GEOLOB=073932800080076800-136.9774560321+045.1446198929"
END
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Different-OUTPUTFORMAT-options-for-each-layer-in-a-mapfile-tp5570778p5570778.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
