[mapserver-users] Open failed for OGR connection
Murat Beyhan
beyhan at deprem.gov.tr
Sun Sep 26 13:21:16 EDT 2010
Dear friends,
I could not solve the problem for OGR connections.
from terminal I use the following codes and it works fine
[murat at localhost makedaskmap]$ ogrinfo
"MySQL:testogr,user=root,password=mysql_123"
INFO: Open of `MySQL:testogr,user=root,password=mysql_123'
using driver `MySQL' successful.
1: deniz (Polygon)
2: il_merkezleri (Point)
3: il_sinirlari (Polygon)
4: ilce_merkezleri (Point)
5: ilce_sinirlari (Polygon)
6: iller (Polygon)
7: iller_sil (Polygon)
8: komsular (Polygon)
But when I try to read data from mysql database it doesn't work for it.
and mapserver gives error as follows
msDrawMap(): Image handling error. Failed to draw layer named 'ilcmrk'.
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
`ilcmrk'. File not found or unsupported format.
part of map file as follows for the layer ilcmrk
data ilce_merkezleri is stored in Mysql table testogr as point
I have reganerated the ilce_merkezleri data in MySql database as follows
ogr2ogr -f MySQL MySQL:testogr,user=root,password=mysql_123 ilcmrk.shp
-nln ilce_merkezleri -update -overwrite -lco GEOMETRY_NAME=SHAPE2
LAYER
connectiontype ogr
CONNECTION "MySQL:testogr,user=root,password=mysql_123"
NAME "ilcmrk"
DATA ilce_merkezleri
STATUS default
TYPE POINT
CLASS
NAME "iLCE MERKEZi"
SYMBOL "cpoint"
SIZE 1
COLOR 72 118 255
END
END
What is wrong with my procedures. Please help me.
Murat
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
