[mapserver-users] Expressions
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Sep 29 15:21:46 EDT 2010
How are you calling mapserver directly?
You need to do something like:
http://host/cgi-bin/mapserv?.....&LASTTWOWEEKS=100916
-Steve
On 9/29/2010 3:12 PM, Jay Kapalczynski wrote:
> I changed the format to and using another field (‘GEO_TIME’ - still numeric)
> <param type="today" offset="-14" name="LASTTWOWEEKS" *format="%2Y%2M%2D"* />
> Instead of:
> <param type="today" offset="-14" name="LASTTWOWEEKS" *format="%4Y%2M%2D"* />
> This worked….
> EXPRESSION ([GEO_TIME] > 100916) THIS DRAWS THE CORRECT 5 POINTS ONLY
> EXPRESSION ([GEO_TIME] > 090110) THIS DRAWS ALL THE POINTS, WHICH IS
> CORRECT… all are > than this date
> I then tried WITH NO SUCCESS
> EXPRESSION ([GEO_TIME] > '%LASTTWOWEEKS%') nothing
> EXPRESSION ([GEO_TIME] > %LASTTWOWEEKS%) nothing
> EXPRESSION ([GEO_TIME] > LASTTWOWEEKS) nothing
> EXPRESSION ('[GEO_TIME]' > '%LASTTWOWEEKS%') THIS DRAWS ALL THE POINTS
> EXPRESSION ('[GEO_TIME]' > %LASTTWOWEEKS%) nothing
> EXPRESSION ('[GEO_TIME]' > LASTTWOWEEKS) nothing
> *_The crazy thing is that I have this working on GEOMOOSE v1.6 on an XP
> 32 bit box….SAME CODE, SAME DATASET..SOMETHING WITH GEOMOOSE 2?????_*
> *With something like this*
> EXPRESSION ('[GEO_SIMPLE]' = 'BURGLARY' AND '[GEO_TIME]' > '%LASTWEEK%')
> -----Original Message-----
> From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
> Sent: Wednesday, September 29, 2010 12:51 PM
> To: Jay Kapalczynski
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Expressions
> First lets get rid of the parameter substitution to make sure we have a
> syntax correct. So in your mapfile try:
> EXPRESSION ([IncidentDa] > 20100816)
> I set this to Aug 16th to see if you can pull any records. Also because
> this is numeric, I removed the quotes. You can also try it with quotes
> to see what works.
> If this works then try:
> EXPRESSION ([IncidentDa] > %LASTTWOWEEKS%)
> Again without the quotes or with depending on what worked.
> -Steve W
> On 9/29/2010 11:49 AM, Jay Kapalczynski wrote:
> > I thank you for your response....greatly appreciated as I cannot figure
> > this out....
> > I know that I have 4 features in the dataset that have a value of
> > 20100916 that’s 13 days ago....so with the expression below those 4 or 5
> > features should show up....but nothing shows up
> > IncidentDa is the field (long integer)
> > Param type is specifying YYYYMMDD my data has values of 20100916 (13
> days)
> > I have no idea what could be wrong…Thank you all for your help….
> > *.XML file*
> > <map-source name="Burglaries" type="mapserver">
> > <file>./maple_grove_datasets/police/Burglaries.map</file>
> > <param type="today" offset="-90" name="LASTNINTY" format="%4Y%2M%2D" />
> > <param type="today" offset="-30" name="LASTTHIRTY" format="%4Y%2M%2D" />
> > * <param type="today" offset="-14" name="LASTTWOWEEKS"
> > format="%4Y%2M%2D" />*
> > * <param type="today" offset="-7" name="LASTWEEK" format="%4Y%2M%2D" />*
> > <param type="today" offset="0" name="TODAY" format="%4Y%2M%2D" />
> > <layer name="Burglaries"/>
> > </map-source>
> > *.MAP file*
> > CLASS
> > NAME 'Last Weeks'
> > EXPRESSION ('[IncidentDa]' > '%LASTTWOWEEKS%' && '[IncidentDa]' <
> > '%LASTWEEK%')
> > STYLE
> > COLOR 0 100 50
> > SYMBOL "bike"
> > SIZE 12
> > END
> > END
> > BUT if I simply place this in there I get all the points…so something is
> > weird here because most of the dates are older than 7 days.
> > CLASS
> > NAME 'Last Weeks'
> > EXPRESSION ('[IncidentDa]' > '%LASTWEEK%’)
> > STYLE
> > COLOR 0 0 0
> > SYMBOL "tent"
> > SIZE 12
> > END
> > #END
> > From: mapserver-users-bounces at lists.osgeo.org
> > [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
> > Woodbridge
> > Sent: Wednesday, September 29, 2010 8:19 AM
> > To: mapserver-users at lists.osgeo.org
> > In EXPRESSIONS you can evaluate any of the following:
> > 1. Regular expressions treating the value as a string
> > 2. numeric expressions using booleans like ==,<,>,<=,>=
> > 3. string expressions like ==, !=, and I think strlen()
> > So if you converted you dates into a format like YYYYMMDD then it would
> > be easy to use a numeric expression like:
> > EXPRESSION ('[dateValues]' > '%STARTDATE%' && '[dateValues]' <
> '%ENDDATE%')
> > or
> > EXPRESSION ('[dateValues]' > '%STARTDATE%')
> > where STARTDATE is the YYYYMMDD value of two weeks ago and ENDDATE would
> > be in the same format and allow you to extract record betwee any two
> > start and end dates.
> > Or you might be able to figure out a complex regular expression the
> > represents the last two weeks like:
> > EXPRESSION ('[dateValues]' =~ '/%LASTTWOWEEKS%/')
> > I'm not sure what you would need for the regular expression.
> > -Steve W
> > On 9/28/2010 4:23 PM, Jay Kapalczynski wrote:
> > > Anyone have anymore ideas about this….
> > > I have a string field with values
> > > And the code below. The expression does not seem to be running…if I
> only
> > > use LASTTWOWEEKS it still draws all the points….and I know there are
> > > values in there from 2008
> > > Thanks
> > > *From:* mapserver-users-bounces at lists.osgeo.org
> > > [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Jay
> > > Kapalczynski
> > > *Sent:* Tuesday, September 21, 2010 9:51 AM
> > > *To:* 'Bob Basques'; mapserver-users at lists.osgeo.org
> > > *Subject:* RE: [mapserver-users] Expressions
> > > My major question is can I do this with a String/text field? Its the
> > > only way I can see keeping things in a %2Y%2M%2D format ex. 092110
> (Sept
> > > 21^st 2010), otherwise the 0 will get removed in a numeric field
> > > Can I use the format Year, Month, Day? Or do I have to use Month,
> > Day, Year?
> > > In this example I eliminated two expressions and focused on one
> > > Expression to see if it is working.
> > > *_I kept this_*
> > > <param type="today" offset="-7" name="LASTWEEK" format="%2Y%2M%2D" />
> > > <param type="today" offset="-90" name="LASTNINTY" format="%2Y%2M%2D" />
> > > </map-source>
> > > *_In my map file I used _**_ONLY_**_ this_*
> > > CLASS
> > > NAME 'Last Weeks'
> > > EXPRESSION ('[dateValues]' > '%LASTTWOWEEKS%')
> > > STYLE
> > > COLOR 0 100 50
> > > SYMBOL "bike"
> > > SIZE 12
> > > END
> > > END
> > > Now in my data I have these values (below), although every symbol was
> > > displayed in the map
> > > NOTE THIS IS A TEXT FIELD
> > > 081204, 081225,090118
> > > These values (above) for the Year, Month, Day format specified in the
> > > map source are clearly less than the “last two weeks”, Where as
> they are
> > > older than the last 14 days….so none of them should show up, but
> they do
> > > Any thoughts
> > > [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Bob
> > Basques
> > > *Sent:* Friday, September 17, 2010 9:25 PM
> > > *To:* mapserver-users at lists.osgeo.org
> > > *Subject:* Re: [mapserver-users] Expressions
> > > A first stab at seeing more than one class, might be to try and switch
> > > them around order wise, one filter may be overwriting the other for
> > example.
> > > bobb
> > > On 9/17/2010 8:20 AM, Jay Kapalczynski wrote:
> > > I am using GeoMoose but feel this is more a question for Map Server.
> > > I am trying to sort my points by dates using the code below….I think
> > > that I can do this but not sure
> > > Is this a viable format “2Y%2M%2D” ?
> > > As for the field in the shapefile…If I use an integer it removes the 0
> > > from the 092110, (sept 21^st 2010)
> > > If I use a date then there are “/” … 9/21/10
> > > The only way I can see this happening is using a text field with
> retains
> > > the 0 in 092110
> > > When I use the textfield “dateValues” as seen below I can get the stars
> > > to draw but only the LASTWEEK…for some reason the LASTTWOWEEKS does not
> > > show and I know that I have a few records with dates in the last 14
> days…
> > > Thoughts?
> > > THANKS….all your help is very appreciated….
> > > Main .xml file
> > > </map-source>
> > > .map file
> > > CLASS
> > > NAME 'Last Weeks'
> > > EXPRESSION ('[dateValues]' > '%LASTWEEK%')
> > > STYLE
> > > COLOR 0 0 0
> > > SYMBOL "star"
> > > SIZE 12
> > > END
> > > END
> > > CLASS
> > > NAME 'Last Two Weeks'
> > > STYLE
> > > COLOR 0 100 50
> > > SYMBOL "star"
> > > SIZE 12
> > > END
> > > END
> > > _______________________________________________
> > > mapserver-users mailing list
> <mailto:mapserver-users at lists.osgeo.org>
> > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
