[mapserver-users] lighttpd, TNS:could not resolve...
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Sep 30 04:37:01 EDT 2010
For me, sometimes with some Oracle user name from some computers SQL*Plus does not understand if I am using the SERVICE_NAME. It you happen to have the same situation you should be able to connect with the connection name, which seems to be MFUATDB for you.
Actually, the error message "TNS:could not resolve the connect identifier specified" may mean that you should not use service name but the connect identifier. Have a try and tell how it went.
-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Sebastian E. Ovide
Lähetetty: 30. syyskuuta 2010 11:15
Vastaanottaja: Dan Little
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] lighttpd, TNS:could not resolve...
yes.
gis at mapserver:~$ ls -la /home/gis/conf/tnsnames.ora
-rw-r--r-- 1 gis gis 184 2010-09-29 16:19 /home/gis/conf/tnsnames.ora
gis at mapserver:~$ sudo su www-data -c 'cat /home/gis/conf/tnsnames.ora'
MFUATDB =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.60.70)(PORT = 1521))
(CONNECT_DATA =
(SERVER = DEDICATED)
(SERVICE_NAME = mfuatdb)
On Wed, Sep 29, 2010 at 7:58 PM, Dan Little <danlittle at yahoo.com> wrote:
Is tnsnames.ora accessible by the web-server user? (Check the permissions.)
Is t
From: Sebastian E. Ovide <sebastian.ovide at gmail.com>
To: mapserver-users at lists.osgeo.org
Sent: Wed, September 29, 2010 11:10:09 AM
Subject: [mapserver-users] lighttpd, TNS:could not resolve...
Hi All,
I have installed MapServer on lighttpd + fastcgi.
fastcgi.server = (
"/mapserver" =>
( "localhost" =>
"socket" => "/tmp/mapserver-fastcgi.socket",
"bin-path" => "/home/gis/bin/mapserv",
"bin-environment" =>
"TNS_ADMIN" => "/home/gis/conf/"
"max-procs" => 2,
"check-local" => "disable"
gis at mapserver:~$ cat /home/gis/conf/tnsnames.ora
MFUATDB =
(DESCRIPTION =
(CONNECT_DATA =
and I'm getting:
msDrawMap(): Image handling error. Failed to draw layer named 'TESTII'. msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `TESTII'. ORA-12154: TNS:could not resolve the connect identifier specified in <unnamed>
from the logs:
[Wed Sep 29 17:00:13 2010].649965 CGI Request 1 on process 1513
[Wed Sep 29 17:00:13 2010].717290 msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `TESTII'.
in <unnamed>
[Wed Sep 29 17:00:13 2010].717319 msDrawMap(): Image handling error. Failed to draw layer named 'TESTII'.
[Wed Sep 29 17:00:13 2010].717454 msFreeMap(): freeing map at 0xa00f298.
[Wed Sep 29 17:00:13 2010].717579 freeLayer(): freeing layer at 0xa0237a0.
[Wed Sep 29 17:00:13 2010].717591 freeLayer(): freeing layer at 0xa024718.
in mapserver:
LAYER
NAME TESTII
TYPE POLYGON
STATUS ON
CONNECTION "OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb"
CONNECTIONTYPE OGR
DATA "CA_WILDFIRE"
PROJECTION
"init=epsg:3857"
END
CLASS
# NAME "local_shape"
COLOR 0 0 255
OUTLINECOLOR 0 0 255
END
END
The connection string is right as I'm using it from gdal:
gis at mapserver:~$ ogrinfo OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE
INFO: Open of `OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE'
using driver `OCI' successful.
1: CA_WILDFIRE
any ideas ?
Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100930/2099df7c/attachment.html
