[mapserver-users] lighttpd, TNS:could not resolve...
Sebastian E. Ovide
sebastian.ovide at gmail.com
Thu Sep 30 04:15:06 EDT 2010
yes.
gis at mapserver:~$ ls -la /home/gis/conf/tnsnames.ora
-rw-r--r-- 1 gis gis 184 2010-09-29 16:19 /home/gis/conf/tnsnames.ora
gis at mapserver:~$ sudo su www-data -c 'cat /home/gis/conf/tnsnames.ora'
MFUATDB =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.60.70)(PORT = 1521))
(CONNECT_DATA =
(SERVER = DEDICATED)
(SERVICE_NAME = mfuatdb)
On Wed, Sep 29, 2010 at 7:58 PM, Dan Little <danlittle at yahoo.com> wrote:
> Is tnsnames.ora accessible by the web-server user? (Check the permissions.)
> Is t
> *From:* Sebastian E. Ovide <sebastian.ovide at gmail.com>
> *To:* mapserver-users at lists.osgeo.org
> *Sent:* Wed, September 29, 2010 11:10:09 AM
> *Subject:* [mapserver-users] lighttpd, TNS:could not resolve...
> Hi All,
> I have installed MapServer on lighttpd + fastcgi.
> fastcgi.server = (
> "/mapserver" =>
> ( "localhost" =>
> "socket" => "/tmp/mapserver-fastcgi.socket",
> "bin-path" => "/home/gis/bin/mapserv",
> "bin-environment" =>
> "TNS_ADMIN" => "/home/gis/conf/"
> "max-procs" => 2,
> "check-local" => "disable"
> gis at mapserver:~$ cat /home/gis/conf/tnsnames.ora
> MFUATDB =
> (DESCRIPTION =
> (CONNECT_DATA =
> and I'm getting:
> msDrawMap(): Image handling error. Failed to draw layer named 'TESTII'.
> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
> `TESTII'. ORA-12154: TNS:could not resolve the connect identifier specified
> in <unnamed>
> from the logs:
> [Wed Sep 29 17:00:13 2010].649965 CGI Request 1 on process 1513
> [Wed Sep 29 17:00:13 2010].717290 msOGRFileOpen(): OGR error. Open failed
> for OGR connection in layer `TESTII'.
> in <unnamed>
> [Wed Sep 29 17:00:13 2010].717319 msDrawMap(): Image handling error. Failed
> [Wed Sep 29 17:00:13 2010].717454 msFreeMap(): freeing map at 0xa00f298.
> [Wed Sep 29 17:00:13 2010].717579 freeLayer(): freeing layer at 0xa0237a0.
> [Wed Sep 29 17:00:13 2010].717591 freeLayer(): freeing layer at 0xa024718.
> in mapserver:
> LAYER
> NAME TESTII
> TYPE POLYGON
> STATUS ON
> CONNECTION "OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb"
> CONNECTIONTYPE OGR
> DATA "CA_WILDFIRE"
> PROJECTION
> "init=epsg:3857"
> END
> CLASS
> # NAME "local_shape"
> COLOR 0 0 255
> OUTLINECOLOR 0 0 255
> END
> END
> The connection string is right as I'm using it from gdal:
> gis at mapserver:~$ ogrinfo OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE
> INFO: Open of `OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE'
> using driver `OCI' successful.
> 1: CA_WILDFIRE
> any ideas ?
> Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100930/22528c35/attachment.html
