[mapserver-users] wfs filter request
Yewondwossen Assefa
yassefa at dmsolutions.ca
Thu Sep 30 09:58:19 EDT 2010
Hi There,
I have loged this in http://trac.osgeo.org/mapserver/ticket/3557. Fix
is committed for the 5.6 branch. Please give it a try and update the bug.
regards,
On 30/09/2010 3:43 AM, Holger Porath wrote:
> Hi again!
> We are still having issues with using mapserver 5.6.5 as a wfs server
> together. When we submit a wfs getfeature filter request mapserver
> doesn't use the filter in the sql statement. It just searches all the
> objects in the database and applies the filter on the result. Thus, we
> are getting a timeout.
> Here is our filter request:
> Filter=<Filter><PropertyIsLike wildCard="%" singleChar="?"
> escape="ESC"><PropertyName>FS_FSZ</PropertyName><Literal>111</Literal></PropertyIsLike></Filter>
> As you can see the filter for the attribute "FS_FSZ" is set to "111".
> The debug log shows that this isn't used in the sql at all: Using this
> Sql to retrieve the data : SELECT fs_id, FS_GKNR, FS_FLNR, FS_FSZ,
> FS_FSN, FS_FSSTATUS, FS_ID, FS_FSRWERT_ABS, FS_FSHWERT_ABS,
> fs_koordinate FROM os_flst
> I expected to see a where clause like the following: where fs_fsz like
> "111"
> When we switch back to mapserver 5.0.0 we see the correct where clause
> in the debug log. So what are we doing wrong or is this a bug?
> Thanks for your help.
> Regards,
> Holger
> This is how our layer definition looks like:
> LAYER
> NAME "test_flst"
> METADATA
> "wfs_extent" "3410000 5470000 3666000 5726000"
> "wfs_title" "test_flst"
> "gml_featureid" "fs_id"
> "gml_include_items" "all" # optional
> END # of METADATA
> TYPE POINT
> STATUS ON
> CONNECTIONTYPE oraclespatial
> CONNECTION "user/pass at service"
> DATA "fs_koordinate from os_flst USING UNIQUE fs_id NONE"
> PROJECTION
> "init=epsg:31467"
> END # of PROJECTION
> DUMP TRUE
> END # of LAYER
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
