[mapserver-users] lighttpd, TNS:could not resolve...
Sebastian E. Ovide
sebastian.ovide at gmail.com
Thu Sep 30 09:01:22 EDT 2010
on the same machine, with the same data and same tns file it works fine with
APACHE.... the problems is only with LIGHTTPD... it looks like "TNS_ADMIN"
=> "/home/gis/conf/" is ignored (in apache I've used SetEnv and PassEnv
On Thu, Sep 30, 2010 at 12:22 PM, Dan Little <danlittle at yahoo.com> wrote:
> Does shp2img work with your Mapfile?
> *From:* Sebastian E. Ovide <sebastian.ovide at gmail.com>
> *To:* Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
> *Cc:* mapserver-users at lists.osgeo.org
> *Sent:* Thu, September 30, 2010 4:47:30 AM
> *Subject:* Re: [mapserver-users] lighttpd, TNS:could not resolve...
> the message says:
> ORA-12154: TNS:could not resolve the connect identifier specified in
> <unnamed>
> so... does <unnamed> mean that gdal didn't get any name for the connection
> On Thu, Sep 30, 2010 at 9:54 AM, Sebastian E. Ovide <
> sebastian.ovide at gmail.com> wrote:
>> no luck...
>> renamed servicename to capital.. so now connection name==service name...
>> same problem... ogrinfo works, mapserver doesn't....
>> On Thu, Sep 30, 2010 at 9:37 AM, Rahkonen Jukka <
>> Jukka.Rahkonen at mmmtike.fi> wrote:
>>> Hi,
>>> For me, sometimes with some Oracle user name from some computers SQL*Plus
>>> does not understand if I am using the SERVICE_NAME. It you happen to have
>>> the same situation you should be able to connect with the connection name,
>>> which seems to be MFUATDB for you.
>>> Actually, the error message "TNS:could not resolve the connect
>>> identifier specified" may mean that you should not use service name but the
>>> connect identifier. Have a try and tell how it went.
>>> -Jukka Rahkonen-
>>> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
>>> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Sebastian E. Ovide
>>> *Lähetetty:* 30. syyskuuta 2010 11:15
>>> *Vastaanottaja:* Dan Little
>>> *Kopio:* mapserver-users at lists.osgeo.org
>>> *Aihe:* Re: [mapserver-users] lighttpd, TNS:could not resolve...
>>> yes.
>>> gis at mapserver:~$ ls -la /home/gis/conf/tnsnames.ora
>>> -rw-r--r-- 1 gis gis 184 2010-09-29 16:19 /home/gis/conf/tnsnames.ora
>>> gis at mapserver:~$ sudo su www-data -c 'cat /home/gis/conf/tnsnames.ora'
>>> MFUATDB =
>>> (DESCRIPTION =
>>> (ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.60.70)(PORT = 1521))
>>> (CONNECT_DATA =
>>> (SERVER = DEDICATED)
>>> (SERVICE_NAME = mfuatdb)
>>> On Wed, Sep 29, 2010 at 7:58 PM, Dan Little <danlittle at yahoo.com> wrote:
>>>> Is tnsnames.ora accessible by the web-server user? (Check the
>>>> permissions.)
>>>> Is t
>>>> *To:* mapserver-users at lists.osgeo.org
>>>> *Sent:* Wed, September 29, 2010 11:10:09 AM
>>>> *Subject:* [mapserver-users] lighttpd, TNS:could not resolve...
>>>> Hi All,
>>>> I have installed MapServer on lighttpd + fastcgi.
>>>> fastcgi.server = (
>>>> "/mapserver" =>
>>>> ( "localhost" =>
>>>> "socket" => "/tmp/mapserver-fastcgi.socket",
>>>> "bin-path" => "/home/gis/bin/mapserv",
>>>> "bin-environment" =>
>>>> "TNS_ADMIN" => "/home/gis/conf/"
>>>> "max-procs" => 2,
>>>> "check-local" => "disable"
>>>> gis at mapserver:~$ cat /home/gis/conf/tnsnames.ora
>>>> MFUATDB =
>>>> (DESCRIPTION =
>>>> (CONNECT_DATA =
>>>> and I'm getting:
>>>> msDrawMap(): Image handling error. Failed to draw layer named 'TESTII'.
>>>> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
>>>> `TESTII'. ORA-12154: TNS:could not resolve the connect identifier specified
>>>> in <unnamed>
>>>> from the logs:
>>>> [Wed Sep 29 17:00:13 2010].649965 CGI Request 1 on process 1513
>>>> [Wed Sep 29 17:00:13 2010].717290 msOGRFileOpen(): OGR error. Open
>>>> failed for OGR connection in layer `TESTII'.
>>>> in <unnamed>
>>>> [Wed Sep 29 17:00:13 2010].717319 msDrawMap(): Image handling error.
>>>> [Wed Sep 29 17:00:13 2010].717454 msFreeMap(): freeing map at 0xa00f298.
>>>> [Wed Sep 29 17:00:13 2010].717579 freeLayer(): freeing layer at
>>>> 0xa0237a0.
>>>> [Wed Sep 29 17:00:13 2010].717591 freeLayer(): freeing layer at
>>>> 0xa024718.
>>>> in mapserver:
>>>> LAYER
>>>> NAME TESTII
>>>> TYPE POLYGON
>>>> STATUS ON
>>>> CONNECTION "OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb"
>>>> CONNECTIONTYPE OGR
>>>> DATA "CA_WILDFIRE"
>>>> PROJECTION
>>>> "init=epsg:3857"
>>>> END
>>>> CLASS
>>>> # NAME "local_shape"
>>>> COLOR 0 0 255
>>>> OUTLINECOLOR 0 0 255
>>>> END
>>>> END
>>>> The connection string is right as I'm using it from gdal:
>>>> gis at mapserver:~$ ogrinfo OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb
>>>> :CA_WILDFIRE
>>>> INFO: Open of `OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE'
>>>> using driver `OCI' successful.
>>>> 1: CA_WILDFIRE
>>>> any ideas ?
>>>> Sebastian E. Ovide
>>> Sebastian E. Ovide
>> Sebastian E. Ovide
> Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100930/5036ef0e/attachment-0001.html
