[mapserver-users] lighttpd, TNS:could not resolve...
Dan Little
danlittle at yahoo.com
Thu Sep 30 09:51:09 EDT 2010
I was starting to suspect MapServer is just no seeing the environment
variables...
Try this... write a wrapper script "mapserv.sh"
#!/bin/bash
TNS_ADMIN=/home/gis/conf
/home/gis/bin/mapserv
Then update your script to point to "mapserv.sh".
>From: Sebastian E. Ovide <sebastian.ovide at gmail.com>
>To: Dan Little <danlittle at yahoo.com>
>Cc: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>; mapserver-users at lists.osgeo.org
>Sent: Thu, September 30, 2010 8:01:22 AM
>Subject: Re: [mapserver-users] lighttpd, TNS:could not resolve...
>on the same machine, with the same data and same tns file it works fine with
>APACHE.... the problems is only with LIGHTTPD... it looks like "TNS_ADMIN" =>
>"/home/gis/conf/" is ignored (in apache I've used SetEnv and PassEnv
>On Thu, Sep 30, 2010 at 12:22 PM, Dan Little <danlittle at yahoo.com> wrote:
>Does shp2img work with your Mapfile?
>>>To: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
>>>Cc: mapserver-users at lists.osgeo.org
>>>Sent: Thu, September 30, 2010 4:47:30 AM
>>>the message says:
>>>ORA-12154: TNS:could not resolve the connect identifier specified in
<unnamed>
>>>so... does <unnamed> mean that gdal didn't get any name for the connection ?
>>>On Thu, Sep 30, 2010 at 9:54 AM, Sebastian E. Ovide <sebastian.ovide at gmail.com>
>>>wrote:
>>>no luck...
>>>>renamed servicename to capital.. so now connection name==service name...
>>>>same problem... ogrinfo works, mapserver doesn't....
>>>>On Thu, Sep 30, 2010 at 9:37 AM, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
>>>>wrote:
>>>>Hi,
>>>>>For me, sometimes with some Oracle user name from some computers SQL*Plus does
>>>>>not understand if I am using the SERVICE_NAME. It you happen to have the same
>>>>>situation you should be able to connect with the connection name, which seems
>>>>>to be MFUATDB for you.
>>>>>Actually, the error message "TNS:could not resolve the connect identifier
>>>>>specified" may mean that you should not use service name but the connect
>>>>>identifier. Have a try and tell how it went.
>>>>>-Jukka Rahkonen-
Lähettäjä: mapserver-users-bounces at lists.osgeo.org
[mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Sebastian E. Ovide
>>>>>>Lähetetty: 30. syyskuuta 2010 11:15
>>>>>>Vastaanottaja: Dan Little
>>>>>>Kopio: mapserver-users at lists.osgeo.org
>>>>>>Aihe: Re: [mapserver-users] lighttpd, TNS:could not resolve...
>>>>>>yes.
>>>>>>gis at mapserver:~$ ls -la /home/gis/conf/tnsnames.ora
>>>>>>-rw-r--r-- 1 gis gis 184 2010-09-29 16:19 /home/gis/conf/tnsnames.ora
>>>>>>gis at mapserver:~$ sudo su www-data -c 'cat /home/gis/conf/tnsnames.ora'
>>>>>>MFUATDB =
>>>>>> (DESCRIPTION =
>>>>>> (ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.60.70)(PORT = 1521))
>>>>>> (CONNECT_DATA =
>>>>>> (SERVER = DEDICATED)
>>>>>> (SERVICE_NAME = mfuatdb)
>>>>>>On Wed, Sep 29, 2010 at 7:58 PM, Dan Little <danlittle at yahoo.com> wrote:
>>>>>>Is tnsnames.ora accessible by the web-server user? (Check the
>>>>>permissions.)
>>>>>>>Is t
>>>>>>>>To: mapserver-users at lists.osgeo.org
>>>>>>>>Sent: Wed, September 29, 2010 11:10:09 AM
>>>>>>>>Subject: [mapserver-users] lighttpd, TNS:could not resolve...
>>>>>>>>Hi All,
>>>>>>>>I have installed MapServer on lighttpd + fastcgi.
>>>>>>>>fastcgi.server = (
>>>>>>>> "/mapserver" =>
>>>>>>>> ( "localhost" =>
>>>>>>>> "socket" =>
>>"/tmp/mapserver-fastcgi.socket",
>>>>>>>> "bin-path" => "/home/gis/bin/mapserv",
>>>>>>>> "bin-environment" =>
>>>>>>>> "TNS_ADMIN" =>
>>>>>"/home/gis/conf/"
>>>>>>>> "max-procs" => 2,
>>>>>>>> "check-local" => "disable"
>>>>>>>>gis at mapserver:~$ cat /home/gis/conf/tnsnames.ora
>>>>>>>>MFUATDB =
>>>>>>>> (DESCRIPTION =
>1521))
>>>>>>>> (CONNECT_DATA =
>>>>>>>>and I'm getting:
>>>>>>>>msDrawMap(): Image handling error. Failed to draw layer named 'TESTII'.
>>>>>>>>msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
>>>>>>>>`TESTII'. ORA-12154: TNS:could not resolve the connect identifier
>>>>>>>>specified in <unnamed>
>>>>>>>>from the logs:
>>>>>>>>[Wed Sep 29 17:00:13 2010].649965 CGI Request 1 on process 1513
>>>>>>>>[Wed Sep 29 17:00:13 2010].717290 msOGRFileOpen(): OGR error. Open failed
>>>>>>>>for OGR connection in layer `TESTII'.
>>>>>>>> in <unnamed>
>>>>>>>>[Wed Sep 29 17:00:13 2010].717319 msDrawMap(): Image handling error.
>>>>>>>>[Wed Sep 29 17:00:13 2010].717454 msFreeMap(): freeing map at
>>>>>>0xa00f298.
>>>>>>>>[Wed Sep 29 17:00:13 2010].717579 freeLayer(): freeing layer at
>>>>>>>>0xa0237a0.
>>>>>>>>[Wed Sep 29 17:00:13 2010].717591 freeLayer(): freeing layer at
>>>>>>>>0xa024718.
>>>>>>>>in mapserver:
>>>>>>>> LAYER
>>>>>>>> NAME TESTII
>>>>>>>> TYPE POLYGON
>>>>>>>> STATUS ON
>>>>>>>> CONNECTION "OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb"
>>>>>>>> CONNECTIONTYPE OGR
>>>>>>>> DATA "CA_WILDFIRE"
>>>>>>>> PROJECTION
>>>>>>>> "init=epsg:3857"
>>>>>>>> END
>>>>>>>> CLASS
>>>>>>>># NAME "local_shape"
>>>>>>>> COLOR 0 0 255
>>>>>>>> OUTLINECOLOR 0 0 255
>>>>>>>> END
>>>>>>>> END
>>>>>>>>The connection string is right as I'm using it from gdal:
>>>>>>>>gis at mapserver:~$ ogrinfo
>>>>>>OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE
>>>>>>>>INFO: Open of `OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE'
>>>>>>>> using driver `OCI' successful.
>>>>>>>>1: CA_WILDFIRE
>>>>>>>>any ideas ?
>>>>>>>>Sebastian E. Ovide
>>>>>>Sebastian E. Ovide
>>>>Sebastian E. Ovide
>>>Sebastian E. Ovide
>Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100930/764158dc/attachment.html
