[mapserver-users] lighttpd, TNS:could not resolve...
Sebastian E. Ovide
sebastian.ovide at gmail.com
Thu Sep 30 09:54:38 EDT 2010
updates.
even if it works with APACHE + CGI, it does NOT work with APACHE+FASTCGI
(AppClass /home/gis/bin/mapserv -initial-env TNS_ADMIN=/home/gis/conf/)
On Thu, Sep 30, 2010 at 2:01 PM, Sebastian E. Ovide <
sebastian.ovide at gmail.com> wrote:
> on the same machine, with the same data and same tns file it works fine
> with APACHE.... the problems is only with LIGHTTPD... it looks like "TNS_ADMIN"
> => "/home/gis/conf/" is ignored (in apache I've used SetEnv and PassEnv
> On Thu, Sep 30, 2010 at 12:22 PM, Dan Little <danlittle at yahoo.com> wrote:
>> Does shp2img work with your Mapfile?
>> *From:* Sebastian E. Ovide <sebastian.ovide at gmail.com>
>> *To:* Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
>> *Cc:* mapserver-users at lists.osgeo.org
>> *Sent:* Thu, September 30, 2010 4:47:30 AM
>> *Subject:* Re: [mapserver-users] lighttpd, TNS:could not resolve...
>> the message says:
>> ORA-12154: TNS:could not resolve the connect identifier specified in
>> <unnamed>
>> so... does <unnamed> mean that gdal didn't get any name for the connection
>> On Thu, Sep 30, 2010 at 9:54 AM, Sebastian E. Ovide <
>>> no luck...
>>> renamed servicename to capital.. so now connection name==service name...
>>> same problem... ogrinfo works, mapserver doesn't....
>>> On Thu, Sep 30, 2010 at 9:37 AM, Rahkonen Jukka <
>>> Jukka.Rahkonen at mmmtike.fi> wrote:
>>>> Hi,
>>>> For me, sometimes with some Oracle user name from some computers
>>>> SQL*Plus does not understand if I am using the SERVICE_NAME. It you happen
>>>> to have the same situation you should be able to connect with the connection
>>>> name, which seems to be MFUATDB for you.
>>>> Actually, the error message "TNS:could not resolve the connect
>>>> identifier specified" may mean that you should not use service name but the
>>>> connect identifier. Have a try and tell how it went.
>>>> -Jukka Rahkonen-
>>>> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
>>>> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Sebastian E. Ovide
>>>> *Lähetetty:* 30. syyskuuta 2010 11:15
>>>> *Vastaanottaja:* Dan Little
>>>> *Kopio:* mapserver-users at lists.osgeo.org
>>>> *Aihe:* Re: [mapserver-users] lighttpd, TNS:could not resolve...
>>>> yes.
>>>> gis at mapserver:~$ ls -la /home/gis/conf/tnsnames.ora
>>>> -rw-r--r-- 1 gis gis 184 2010-09-29 16:19 /home/gis/conf/tnsnames.ora
>>>> gis at mapserver:~$ sudo su www-data -c 'cat /home/gis/conf/tnsnames.ora'
>>>> MFUATDB =
>>>> (DESCRIPTION =
>>>> (ADDRESS = (PROTOCOL = TCP)(HOST = 192.168.60.70)(PORT = 1521))
>>>> (CONNECT_DATA =
>>>> (SERVER = DEDICATED)
>>>> (SERVICE_NAME = mfuatdb)
>>>> On Wed, Sep 29, 2010 at 7:58 PM, Dan Little <danlittle at yahoo.com>wrote:
>>>>> Is tnsnames.ora accessible by the web-server user? (Check the
>>>>> permissions.)
>>>>> Is t
>>>>> *To:* mapserver-users at lists.osgeo.org
>>>>> *Sent:* Wed, September 29, 2010 11:10:09 AM
>>>>> *Subject:* [mapserver-users] lighttpd, TNS:could not resolve...
>>>>> Hi All,
>>>>> I have installed MapServer on lighttpd + fastcgi.
>>>>> fastcgi.server = (
>>>>> "/mapserver" =>
>>>>> ( "localhost" =>
>>>>> "socket" => "/tmp/mapserver-fastcgi.socket",
>>>>> "bin-path" => "/home/gis/bin/mapserv",
>>>>> "bin-environment" =>
>>>>> "TNS_ADMIN" => "/home/gis/conf/"
>>>>> "max-procs" => 2,
>>>>> "check-local" => "disable"
>>>>> gis at mapserver:~$ cat /home/gis/conf/tnsnames.ora
>>>>> MFUATDB =
>>>>> (DESCRIPTION =
>>>>> (CONNECT_DATA =
>>>>> and I'm getting:
>>>>> msDrawMap(): Image handling error. Failed to draw layer named 'TESTII'.
>>>>> msOGRFileOpen(): OGR error. Open failed for OGR connection in layer
>>>>> `TESTII'. ORA-12154: TNS:could not resolve the connect identifier specified
>>>>> in <unnamed>
>>>>> from the logs:
>>>>> [Wed Sep 29 17:00:13 2010].649965 CGI Request 1 on process 1513
>>>>> [Wed Sep 29 17:00:13 2010].717290 msOGRFileOpen(): OGR error. Open
>>>>> failed for OGR connection in layer `TESTII'.
>>>>> in <unnamed>
>>>>> [Wed Sep 29 17:00:13 2010].717319 msDrawMap(): Image handling error.
>>>>> [Wed Sep 29 17:00:13 2010].717454 msFreeMap(): freeing map at
>>>>> 0xa00f298.
>>>>> [Wed Sep 29 17:00:13 2010].717579 freeLayer(): freeing layer at
>>>>> 0xa0237a0.
>>>>> [Wed Sep 29 17:00:13 2010].717591 freeLayer(): freeing layer at
>>>>> 0xa024718.
>>>>> in mapserver:
>>>>> LAYER
>>>>> NAME TESTII
>>>>> TYPE POLYGON
>>>>> STATUS ON
>>>>> CONNECTION "OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb"
>>>>> CONNECTIONTYPE OGR
>>>>> DATA "CA_WILDFIRE"
>>>>> PROJECTION
>>>>> "init=epsg:3857"
>>>>> END
>>>>> CLASS
>>>>> # NAME "local_shape"
>>>>> COLOR 0 0 255
>>>>> OUTLINECOLOR 0 0 255
>>>>> END
>>>>> END
>>>>> The connection string is right as I'm using it from gdal:
>>>>> gis at mapserver:~$ ogrinfo OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb
>>>>> :CA_WILDFIRE
>>>>> INFO: Open of `OCI:GEO_US_DATA/GEO_US_DATA at mfuatdb:CA_WILDFIRE'
>>>>> using driver `OCI' successful.
>>>>> 1: CA_WILDFIRE
>>>>> any ideas ?
>>>>> Sebastian E. Ovide
>>>> Sebastian E. Ovide
>>> Sebastian E. Ovide
>> Sebastian E. Ovide
> Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100930/c3991523/attachment-0001.html
