[mapserver-users] WFS Intersect with gml:box
Joaquín Rodriguez-Guerra Urcelay
jrguerra at gmv.com
Fri Apr 1 15:09:14 EDT 2011
Hello,
Today I had time to try this test in 3 different systems, and I couldn make it work in any of them, so I think this is a bug, should I create a new ticket in http://trac.osgeo.org/mapserver/.
I write the steps below to reproduce the problem
PROBLEM:
In wfs layer where the data is retrieved from a mysql table, the intersect filter only returns a result list when the first feature(the first inserted record in the table) is part of the result set. If the filter shall return results, but the first feature is not among them, then we get not list of features:
<?xml version='1.0' encoding="ISO-8859-1" ?>
<wfs:FeatureCollection...>
<gml:boundedBy>
<gml:Box srsName="EPSG:4326">
<gml:coordinates>-1.000000,-1.000000 -1.000000,-1.000000</gml:coordinates>
</gml:Box>
</gml:boundedBy>
</wfs:FeatureCollection>
Which is diffrent to when a query shall not return any resultst:
<wfs:FeatureCollection...">
<gml:boundedBy>
<gml:null>missing</gml:null>
</gml:boundedBy>
TEST:
1. Create Spatial Data
CREATE DATABASE mmi_spatial_db;
USE mmi_spatial_db;
CREATE TABLE positionReal (oid LONG, point POINT);
INSERT INTO positionReal(oid, point) VALUES (3, GeomFromText('POINT(-10 -10)',4326));
INSERT INTO positionReal(oid, point) VALUES (2, GeomFromText('POINT(10 10)',4326));
INSERT INTO positionReal(oid, point) VALUES (1, GeomFromText('POINT(0 20)',4326));
2. Map file:
MAP
NAME MMI_WFS
UNITS METERS
TRANSPARENT ON
IMAGECOLOR 0 0 0
IMAGETYPE PNG
SHAPEPATH "."
SYMBOLSET "../symbols.sym"
STATUS ON
WEB
IMAGEPATH "/opt/fsg/tmp/"
IMAGEURL "/opt/fsg/"
METADATA
"wfs_title" "WFS MMI Server for MapServer" ## REQUIRED
"wfs_onlineresource" "http://localhost:8080/cgi-bin/mywfs?" ## Recommended
"wfs_srs" "EPSG:4326"## Recommended
"wfs_abstract" "This text describes my WFS service." ## Recommended
"wfs_schemas_location" "http://schemas.opengeospatial.net"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "PositionReal"
STATUS ON
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "MySQL:mmi_spatial_db,user=mmi,password=*****,host=127.0.0.1,port=3306"
DATA "SELECT point from positionReal"
#CONNECTIONTYPE POSTGIS
#CONNECTION "host=127.0.0.1 port=5432 dbname=mmi_db user=postgres password=postgres"
#DATA "point from positionreal"
DUMP TRUE ## REQUIRED
#TOLERANCE 200
#TOLERANCEUNITS PIXELS
METADATA
#"wfs_featureid" "oid"
"wfs_srs" "epsg:4326"
"wfs_title" "PositionReal"
"gml_include_items" "all" ## Optional (serves all attributes for lay
"gml_surface_occurances" "0,UNBOUNDED"
"wfs_extent" "-180 -90 180 90"
END
END
END # Map File
3. Intersect Filter:
- This one works because point (-10,-10) is part of the resultset.
http://localhost:8080/cgi-bin/mywfs?SERVICE=WFS&VERSION=1.0.0&request=getfeature&typename=PositionReal&Filter=
<Filter xmlns="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml"><Intersects><PropertyName>point</PropertyName>
<gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>-180,-90 -180,90 180,90 180,-90 -180,-90</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></Filter>
- This one works, point (-10,-10) is part of the resultset
<gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>-11,-11 -11,-9 -9,-9 -9,-11 -11,-11</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></Filter>
- This query fails, it should return one feature, but we get the weird behavior because point (-10,-10) is not part of the resultset
<gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>9,9 9,11 11,11 11,9 9,9</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></Filter>
Notice that I use gml:polygon instead of gml:box to be able to test this with mapserver in trunk (which works with gml:box) but also with mapserver 5.6.3 (fgs-installer, which dont work with intersect and gml:box)
The problem does not ocurr if the database in use is postgres
./createdb -U postgres -T template_postgis mmi_db;
CREATE TABLE positionReal (oid int);
SELECT AddGeometryColumn('positionreal', 'point', 4326,'POINT',2);
SYSTEMS:
I test this in the following systems:
OpenSuse 11
fgs-mapserver_basic_5.6.3-fgs_9.5-linux-i386.bin and building from the sources (branch 5-6)
mysql Ver 14.12 Distrib 5.0.67, for suse-linux-gnu (i686) using readline 5.2 and mysql 5.5 too
SLES 11
mysql Ver 14.14 Distrib 5.1.43, for unknown-linux-gnu (x86_64) using readline 5.1
Ubunut
mysql 5.1
Best regards,
Joaquín
________________________________________
De: Joaquín Rodriguez-Guerra Urcelay
Enviado el: jueves, 31 de marzo de 2011 17:25
Para: mapserver-users at lists.osgeo.org
Asunto: RE: [mapserver-users] WFS Intersect with gml:box
I have check the same example using Posgres and it works, so it is a problem with mysql
Joaquín Rodríguez-Guerra Urcelay
Unidad de Sistemas de Procesamiento de Ciencia y de Observación de la Tierra / Science and Earth Observing Processing Systems Unit
GMV AEROSPACE AND DEFENCE, S.A.
Isaac Newton, 11
P.T.M. Tres Cantos
E-28760 Madrid
Tel. +34 91 807 21 00 / 7695
Fax +34 91 807 21 99
www.gmv.com
De: mapserver-users-bounces at lists.osgeo.org [mapserver-users-bounces at lists.osgeo.org] En nombre de Joaquín Rodriguez-Guerra Urcelay [jrguerra at gmv.com]
Enviado el: jueves, 31 de marzo de 2011 16:42
Hello,
Here I am again, this is not over :(
I have been testing this all morning, and I have seen that intersect only returns results when the first feature in the mysql table belongs to the resultset, very weird :(
When I request a filter which should return results, but the first feature is not in the resultset, then I get this:
<gml:boundedBy>
</gml:Box>
</gml:boundedBy>
Which is diffrent to when I make a query which should not return any results, then I get:
<gml:boundedBy>
</gml:boundedBy>
So, it detects when there are results, but only show them when the first feature is on the result set. Does this make any sense?
This is my database (mysql 5):
USE mmi_spatial_db;
CREATE TABLE positionReal (id INTEGER, point GEOMETRY);
INSERT INTO positionReal(id, point) VALUES (2, GeomFromText('POINT(10 10)',4326));
INSERT INTO positionReal(id, point) VALUES (1, GeomFromText('POINT(0 20)',4326));
INSERT INTO positionReal(id, point) VALUES (3, GeomFromText('POINT(-10 -10)',4326));
The following query returns the expected result
<gml:Box srsName="epsg:4326"><gml:coordinates decimal="." cs="," ts=" ">10,10 10,10</gml:coordinates>
</gml:Box>
</Intersects>
</Filter>
result:
<gml:boundedBy>
<gml:coordinates>10.000000,10.000000 10.000000,10.000000</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<ms:PositionReal fid="PositionReal.2">
<gml:boundedBy>
</gml:Box>
</gml:boundedBy>
<ms:msGeometry>
<gml:Point srsName="EPSG:4326">
<gml:coordinates>10.000000,10.000000</gml:coordinates>
</gml:Point>
</ms:msGeometry>
<ms:id>2</ms:id>
</ms:PositionReal>
</gml:featureMember>
And any other query where the point 10,10 is belonging the bounding box, works. If I change the order INSERTS, then this magic point changes for the one I insert first.
This is my map file:
MAP
NAME MMI_WFS
UNITS METERS
TRANSPARENT ON
IMAGECOLOR 0 0 0
IMAGETYPE PNG
SHAPEPATH "."
STATUS ON
WEB
METADATA
END
END
PROJECTION
"init=epsg:4326"
END
LAYER
NAME "PositionReal"
STATUS ON
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "MySQL:mmi_spatial_db,user=mmi,password=adminis,host=127.0.0.1,port=3306"
DATA "SELECT id,point from positionReal"
#TOLERANCE 200
METADATA
"wfs_featureid" "id"
END
END
END # Map File
Well, this is weird, but if it sounds familliar or it rings a bell to some one, please help me :)
Thanks!
Joaquín
Enviado el: jueves, 31 de marzo de 2011 11:31
CC: mapserver-users at lists.osgeo.org
Thank you both for your help, the filter is finally working :D
The bug is fixed, gml:box works now with intersect. I wanted to confirm this in the bug report, but I havent found they way to write anything there (is it because the bug is now closed?)
Yesterday I was not getting the results I expected because I think my connection to the mysql database had some problem. I tried with a shapefile and it was working perfectly, so I then played a bit with the mysql connection and now it is working :)
Joaquín
De: Yewondwossen Assefa [yassefa at dmsolutions.ca]
Enviado el: miércoles, 30 de marzo de 2011 22:48
Para: Rahkonen Jukka
CC: mapserver-users at lists.osgeo.org; Joaquín Rodriguez-Guerra Urcelay
Asunto: Re: [mapserver-users] WFS Intersect with gml:box
On 30/03/2011 4:16 PM, Rahkonen Jukka wrote:
> Hi,
> "Intersect" means the same as "not disjoint", that the two geometries have at least one point in common. Thus WFS Intersects should select the point that is inside the "box" in the query. I made a quick test with OpenJUMP which is using JTS and it really does select such a point with a apatial query Intersects.
Geos lib used by MapServer should act the same as JTS I beleive.
Joaquín, you can maybe attach your simple map/data/url to the bug and I
will check it using MapServer trunk.
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
This message including any attachments may contain confidential
information, according to our Information Security Management System,
and intended solely for a specific individual to whom they are addressed.
Any unauthorised copy, disclosure or distribution of this message
is strictly forbidden. If you have received this transmission in error,
please notify the sender immediately and delete it.
Este mensaje, y en su caso, cualquier fichero anexo al mismo,
puede contener informacion clasificada por su emisor como confidencial
en el marco de su Sistema de Gestion de Seguridad de la
Informacion siendo para uso exclusivo del destinatario, quedando
prohibida su divulgacion copia o distribucion a terceros sin la
autorizacion expresa del remitente. Si Vd. ha recibido este mensaje
erroneamente, se ruega lo notifique al remitente y proceda a su borrado.
Gracias por su colaboracion.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
