[mapserver-users] tutorial assistance
martin crook
crookgeo at gmail.com
Sun Apr 3 09:26:24 EDT 2011
I have recently installed mapserver and I get the appropriate message by
using the following command:
http://localhost/cgi-bin/mapserv
I saved the Example1-1.map file to my Apache html directory:
/var/www/html/mapserver/
Example1-1.map
all my data for the tutorial is in:
/var/www/html/mapserver/data
within the mapfile, I modified the path to:
SHAPEPATH "/var/www/html/mapserver/data"
when I use the command in the browswer:
http://localhost/cgi-bin/mapserv&map=/var/www/html/mapserver/Example1-1.map&layer=states&mode=map
I get the following output:
"Object not found!
The requested URL was not found on this server. If you entered the URL
manually please check your spelling and try again.
If you think this is a server error, please contact the
webmaster<root at localhost>.
Error 404 localhost
Apache/2.2.14 (Mandriva Linux/PREFORK-1.5mdv2010.0)"
I have tried many alternate locations and paths to troubleshoot, but cannot
make any of them work. I suspect a permission issue, but am unsure. Please
help.
Thanks in advance.
-Marty
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110403/ac5709e2/attachment.html
