[mapserver-users] how do min/max scale filters work?
PixelPusher
pixelpusher at cox.net
Wed Apr 6 09:10:33 EDT 2011
I’ve got a simple thing in a MapServer page that doesn’t want to work. There is a layer in my map that I only want displayed if the scale of the view is between 1:24000 and 1:100000. However, I’ve had no luck using the MAXSCALEDENOM and MINSCALEDENOM keywords. As configured below, the layer never draws, regardless of the scale. The layer draws correctly if I comment out the scale tests. Can anyone show me the correct way to use this?
The relevant section of the mapfile looks like this:
LAYER
NAME "BTSroads_local_PostGIS"
TYPE LINE
STATUS DEFAULT
MAXSCALEDENOM 100000
MINSCALEDENOM 24000
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=mapserver user=uuuu password=pppp port=5432"
DATA "wkb_geometry from btsroads using unique ogc_fid using srid=4269"
FILTER "fcc LIKE 'A4%'"
CLASS
NAME "Local Roads"
STYLE
COLOR 220 214 196
END
END
END # layer
Thanks,
Thom
Man will occasionally stumble over the truth, but most of the time
he will pick himself up and continue. -- Winston Churchill
