[mapserver-users] error in raster layer
morteza shabihkhani
m.shabihkhani at gmail.com
Fri Apr 8 00:16:56 EDT 2011
Hello all,
I want to create a very simple raster layer, but I faced to this error:
msDrawMap(): Image handling error. Failed to draw layer named 'elevation'.
msDrawRaster(): Unable to access file. stcon using full path stcon
this is my layer:
LAYER
NAME elevation
TYPE raster
STATUS on
DATA stcon
PROJECTION
"init=epsg:2260"
END
CLASS
STYLE
OUTLINECOLOR 0 200 0
END
END
END
I checked paths and names, and everything is correct.
I should note that I try to look at the only raster layer of itasca, but
although all other layers are working very well, running this layer causes
this error:
msDrawMap(): Image handling error. Failed to draw layer named 'drgs'.
msDrawRaster(): Image handling error. Unrecognized or unsupported image
format drawEPP(): Image handling error.
/var/www/Mapserver/Amin(Itasca)/data/drgncimq1926.tif is not an EPPL file.
Thank you in advance for your help.
Amin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110408/f26adc07/attachment.html
