[mapserver-users] RE: making POINT with SQL
Juan Carlos Monestel
juanzito at univali.br
Mon Apr 11 15:32:17 EDT 2011
Hi Jukka,
This is the error in the debug file:
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named 'test'. in /xxx/xx/xx/xxx.php on line 992
Warning: [MapServer Error]: msPOSTGISLayerParseData(): Error parsing POSTGIS data variable. Must contain 'geometry_column from table_name' or 'geom from (subselect) as foo' (couldnt find ' from '). More help: Error with POSTGIS data variable. You specified '%data%'. Standard ways of specifiying are : (1) 'geometry_column from geometry_table' (2) 'geometry_column from (sub query) as foo using unique column name using SRID=srid#' Make sure you put in the 'using unique column name' and 'using SRID=#' clauses in. For more help, please see http://postgis.refractions.net/documentation/ Mappostgis.c - version of Jan 23/2004. in /var/www/html/dev/jmonestel/trunk/app/lib/mapaMapscriptF.class.php on line 992
This is my Layer:
LAYER
NAME test
TYPE POINT
STATUS ON
connectiontype POSTGIS
connection "dbname=xxxx user=xxxxx host=xxxxx port=xxxxx"
data "%data%"
projection
"proj=latlong"
"ellps=WGS84"
"datum=WGS84"
end
CLASS
NAME "juan"
STYLE
SYMBOL 'juan2'
COLOR 0 119 255
SIZE 2
END
END
END # layer
My %data% is "geo_coordenada FROM (select cod_referencia as oid, geo_coordenada, ind_cor from ponto_referencia where cod_referencia = 1 ) as map using SRID=4326"
The SQL brings me an geo info ("0101000020E610000079E9263108DC42C08716D9CEF75338C0") that in text is = "POINT(-37.719 -24.328)"
-----Original Message-----
From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Sent: Thu 4/7/2011 3:35 PM
To: Juan Carlos Monestel; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] RE: making POINT with SQL
First add DEBUG 5, it may generate some interesting information for you into ms_errorfile. Next, comment out maxscale to be sure it is not preventing the rendering. Change it to MAXSCALEDENOM later, maxscale is not to be used any more. Add PROJECTION into your LAYER for getting more control on what is happening. And tell us the exact request you were using. Very often a blank map without any errors means that Mapserver does not find data from the requested map window, and very often it is because of some misconfiguration or misunderstanding with projections.
-Jukka Rahkonen-
Juan Carlos Monestel wrote:
> Hi
> it is not drawing and no error occurs
From: Lime, Steve D (DNR) [mailto:steve.lime at state.mn.us]
Sent: Thu 4/7/2011 2:43 PM
Subject: RE: making POINT with SQL
What does "not working" mean? Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Juan Carlos Monestel
Sent: Thursday, April 07, 2011 12:04 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] making POINT with SQL
Hello
I'm trying to make an POINT in the map but it's not working
this is my Layer
layer
name "ponto"
data "geo_info from table"
type point
status on
metadata
tile_source "nocache"
end
maxscale 3000001
class
style
size 4
symbol "circulo"
color 0 0 0
end
style
size 1
symbol "circulo"
color 255 255 255
end
end
end
Any Ideas ?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110411/ba0fb941/attachment-0001.html
