[mapserver-users] RE: Problems with Query Template (Chameleon)
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Apr 13 08:34:21 EDT 2011
Hello Andy,
I may not have your solution, but I can let you know what I would do in
this situation:
- make sure GDAL/OGR is accessing your file properly (testing with the
ogrinfo command on your old installation version and with your new
installation GDAL version, and compare the ogrinfo results)
- test a simple query on your problem file in something other than
Chameleon (e.g. install the MS4W addon "MapServer Itasca Demo
Application" and try modifying that for your own mapfile, it is a
MapServer CGI viewer with a query tool that you desire)
- once you know if it is an issue specific to Chameleon then move this
question to the Chameleon mailing list
- if it isn't a Chameleon issue, you might have discovered an issue with
MapServer/OGR....so don't give up!
Hope this helps.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 11-04-12 6:28 PM, Andy Hird wrote:
> Steve
> Thanks for the reply.
> There are no errors being logged and as I say it works for files which
> are not MapInfo Tab files. For instance the following works fine.
> LAYER
> NAME "10K StreetView"
> STATUS ON
> TYPE RASTER
> MINSCALEDENOM 6000 #600
> MAXSCALEDENOM 22499 #2999
> TILEINDEX "C:\ms4w\apps\XXXX\data\10K.shp"
> TILEITEM "LOCATION"
> CLASS
> TEMPLATE "templates/XXXX.html" #TOLERANCE 6 TOLERANCEUNITS PIXELS
> END
> END
> I assume that this is because it’s a shp file which has a dbf file.
> This does not work:
> LAYER
> NAME "MasterMap Area"
> TYPE POLYGON
> MINSCALEDENOM 1
> MAXSCALEDENOM 5999
> STATUS ON
> CONNECTIONTYPE OGR
> CONNECTION "C:\ms4w\apps\XXXX\data\MM_Topo_Area.TAB"
> STYLEITEM "AUTO"
> CLASS
> END # Class section
> HEADER "templates/XXXX_header.html"
> FOOTER "templates/XXXX_footer.html"
> END
> Its bugging me like crazy as I can’t figure it out, - the second part of
> my question was:
> “However If someone can provide example of placing a button on a html
> page that would call query functionality that would be very helpful too.”
> If it’s easier for someone to advise on that it would be appreciated.
> Thanks
> Andy
