[mapserver-users] mapserver 6 beta5 and variable substitutions
adams
adams at terrestris.de
Wed Apr 13 10:39:46 EDT 2011
Dear list,
I am just testing around with mapserver 6 beta5 and wonder, if there is
an issue with the variable substitutuions.
Great work so far !! Thanks guys!
... and now my problem ;-):
We set a filter on events due to time and level in the client and send
the parameters via url as variable substitutions to the DATA -request on
postgis in the mapfile:
<mapfile snip>
CONNECTION 'user=....
DATA "geom from (select * from table WHERE level IN (%LEVEL%) AND (date
BETWEEN '%TIME_START%' AND '%TIME_END%' OR ....))) as foo using unique
id using SRID=..."
</mapfile snip>
Calling this via WMS getMap-Request:
http:// ...
/mapserv6?map=maps.map&LAYERS=earthquake&...&LEVEL=1,2,3&TIME_START=2011-03-10&TIME_END=2011-03-24&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&....
Works fine for mapserver 5.6, but fails on mapserver6 (yes, I tried
without variable substitution and all works fine after reading:
http://mapserver.org/trunk/MIGRATION_GUIDE.html - thanks for that!)
This is the xml error I get:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named
'earthquake'.
msPostGISLayerWhichShapes(): Query error. Error (ERROR: syntax error at
or near "%"
LINE 1: ...WHERE head_category_id = 34 AND level IN (%LEVE...
) executing query: select
"level",encode(ST_AsBinary(ST_Force_2D("head_geo"),'NDR'),'hex')
as geom,"id" from (select * from app_head_event WHERE
head_category_id = 34 AND level IN (%LEVEL%) AND (head_time_start::date
head_time_end::date BETWEEN '%TIME_START%' AND
'%TIME_END%' OR (head_time_end::date > '%TIME_END%'
AND head_time_start::date < '%TIME_START%'))) as foo where
head_geo && GeomFromText('POLYGON((11401706.0926982
2783146.86697407,11401706.0926982 5613635.52927973,19986215.8245698
5613635.52927973,19986215.8245698 2783146.86697407,11401706.0926982
2783146.86697407))',900913)
msValidateParameter(): Regular expression error. Parameter pattern
validation failed.
validation failed.
validation failed.
</ServiceException>
</ServiceExceptionReport>
It seems that the var-subs are not passed to the query... or is there
something else I missed?
I just found one issue on variable substitutions:
http://osgeo-org.1803224.n2.nabble.com/MapServer-6-0-0-beta4-release-td6225613.html
But in my eyes this does not explain my problem.
Thanks in advance!
Till
