[mapserver-users] mapserver 6 beta5 and variable substitutions
adams
adams at terrestris.de
Wed Apr 13 11:09:01 EDT 2011
Steve,
:-[ oh,
sorry, it seems that my eyes have become bad ...
OK, I tried this:
'LEVEL_validation_pattern' '1|1,2|1,2,3|1,2,3,4|1,2,3,4,5'
'TIME_START_validation_pattern' '20$|^20'
'TIME_END_validation_pattern' '20$|^20'
'default_LEVEL' '1,2,3,4,5'
'default_TIME_START' '2011-04-01'
'default_TIME_END' '2011-04-30'
In the Maps web-metadata and/or layer-metadata tags, it works fine in
the layer-metadata but not for the maps metadata.
If I understood your discussion on ticket #3522, there were plans to
enable to put this into the maps-metadata tag as well?
Thanks so far!
Regards, Till
Lime, Steve D (DNR) wrote:
> Hi Till: From the migration guide...
> "Runtime subsitution now *requires* a validation pattern be present before the
> substitution will take place (this had been optional). This can be done via
> a layer metadata tag as before or within layer or web VALIDATION blocks. See
> ticket #3522 for more information."
> Could this be it?
> Steve
> -----Original Message-----
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of adams
> Sent: Wednesday, April 13, 2011 9:40 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] mapserver 6 beta5 and variable substitutions
> Dear list,
> I am just testing around with mapserver 6 beta5 and wonder, if there is
> an issue with the variable substitutuions.
> Great work so far !! Thanks guys!
> ... and now my problem ;-):
> We set a filter on events due to time and level in the client and send
> the parameters via url as variable substitutions to the DATA -request on
> postgis in the mapfile:
> <mapfile snip>
> CONNECTION 'user=....
> DATA "geom from (select * from table WHERE level IN (%LEVEL%) AND (date
> BETWEEN '%TIME_START%' AND '%TIME_END%' OR ....))) as foo using unique
> id using SRID=..."
> </mapfile snip>
> Calling this via WMS getMap-Request:
> http:// ...
> /mapserv6?map=maps.map&LAYERS=earthquake&...&LEVEL=1,2,3&TIME_START=2011-03-10&TIME_END=2011-03-24&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&....
> Works fine for mapserver 5.6, but fails on mapserver6 (yes, I tried
> without variable substitution and all works fine after reading:
> http://mapserver.org/trunk/MIGRATION_GUIDE.html - thanks for that!)
> This is the xml error I get:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException>
> msDrawMap(): Image handling error. Failed to draw layer named
> 'earthquake'.
> msPostGISLayerWhichShapes(): Query error. Error (ERROR: syntax error at
> or near "%"
> LINE 1: ...WHERE head_category_id = 34 AND level IN (%LEVE...
> ) executing query: select
> "level",encode(ST_AsBinary(ST_Force_2D("head_geo"),'NDR'),'hex')
> as geom,"id" from (select * from app_head_event WHERE
> head_category_id = 34 AND level IN (%LEVEL%) AND (head_time_start::date
> head_time_end::date BETWEEN '%TIME_START%' AND
> '%TIME_END%' OR (head_time_end::date > '%TIME_END%'
> AND head_time_start::date < '%TIME_START%'))) as foo where
> head_geo && GeomFromText('POLYGON((11401706.0926982
> 2783146.86697407,11401706.0926982 5613635.52927973,19986215.8245698
> 5613635.52927973,19986215.8245698 2783146.86697407,11401706.0926982
> 2783146.86697407))',900913)
> msValidateParameter(): Regular expression error. Parameter pattern
> validation failed.
> validation failed.
> validation failed.
> </ServiceException>
> </ServiceExceptionReport>
> It seems that the var-subs are not passed to the query... or is there
> something else I missed?
> I just found one issue on variable substitutions:
> http://osgeo-org.1803224.n2.nabble.com/MapServer-6-0-0-beta4-release-td6225613.html
> But in my eyes this does not explain my problem.
> Thanks in advance!
> Till
terrestris GmbH & Co. KG
Irmintrudisstrasse 17
53111 Bonn
Germany
Till Adams
Geschäftsführung
Tel: +49 (0)228 / 962 899-52
Fax: +49 (0)228 / 962 899-57
adams at terrestris.de http://www.terrestris.de
Amtsgericht Bonn, HRA 6835
Komplementärin:
terrestris Verwaltungs GmbH
vertreten durch:
Hinrich Paulsen, Till Adams
