[mapserver-users] MapServer 6: ESRI Grid display with KMZ output
Yewondwossen Assefa
yassefa at dmsolutions.ca
Thu Apr 14 10:20:14 EDT 2011
On 14/04/2011 4:13 AM, Cécile Alfred wrote:
> Yes it is.
> Thank you very much. There is just a problem with the latlongbox. It
> seems to use the WIDTH HEIGHT oh the request.
This should be fixed now in svn. Bug related to that issue is at
http://trac.osgeo.org/mapserver/ticket/3840
best regards,
> Cécile
> 2011/4/12 Yewondwossen Assefa <yassefa at dmsolutions.ca
> <mailto:yassefa at dmsolutions.ca>>
> You should comment out CLASSITEM "[pixel]". There is no need to
> add that line from what I can see and in this case seems to make a
> difference.
> Let me know.
> Assefa
> On 11/04/2011 10:35 AM, Cécile Alfred wrote:
>> Hi,
>> there is here the mapfile (test.map), an ESRI ascii grid, a
>> geotiff and requests png and kmz (requests.txt).
>> Thank you
>> Cécile
>> 2011/4/11 Yewondwossen Assefa <yassefa at dmsolutions.ca
>> Hi,
>> If you are willing to share a sample map file + this
>> particular format file, I can look into the kmz output issue.
>> If that is the case, wither send me the sample or open a trac
>> bug and attche the data. Please assign the bug to me (assefa).
>> Assefa
>> On 08/04/2011 8:09 AM, Cécile Alfred wrote:
>>> Hi,
>>> I try to use Mapserver 6 beta 5 to generate kmz output with
>>> several type of input data (geotiff, shape and esri ascii grid):
>>> It is OK with geotiff and shape but there is no result with
>>> grd (empty image in temp).
>>> If I try to generate png output it's OK for all.
>>> Thank you for help
>>> Kelly
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Assefa Yewondwossen
>> Software Analyst
>> Email:yassefa at dmsolutions.ca <mailto:yassefa at dmsolutions.ca>
>> http://www.dmsolutions.ca/
>> Phone: (613) 565-5056 (ext 14)
>> Fax: (613) 565-0925
> Assefa Yewondwossen
> Software Analyst
> Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110414/e6645835/attachment-0001.html
