[mapserver-users] SLD and Offset
Yewondwossen Assefa
yassefa at dmsolutions.ca
Thu Apr 14 11:51:19 EDT 2011
Maybe using the PerpendicularOffset of the stroke element would work in
your case (only availble in sld1.1)? Quick example can be found at
http://www3.dmsolutions.ca/tmp/sld_line_simple_1.1.0_offset.xml
best regards,
On 14/04/2011 11:05 AM, Kickinger Johann wrote:
> I have real time traffic data which has values for one link/line in
> both directions e.g. value 0 (green) in the digitalisation direction
> and value 3 (red) against the digitalisation direction.
> At the moment this is done with OFFSET x -99 and works well. I see the
> link two times with, if available, two different values
> CLASS
> NAME C_0_0
> EXPRESSION (([value_los] = 0) && ([linkdirection] = 0))
> STYLE
> COLOR 0 117 0
> WIDTH 3
> ANTIALIAS TRUE
> OFFSET 2 -99
> END
> END
> CLASS
> NAME C_0_1
> EXPRESSION (([value_los] = 0) && ([linkdirection] = 1))
> STYLE
> COLOR 0 117 0
> WIDTH 3
> ANTIALIAS TRUE
> OFFSET -2 -99
> Now I wanted to use SLD with UserStyle - the color and width is
> changeable, but I noticed that the OFFSET was overruled and so I dont
> see different values for separate directions. I found no parameter in
> the SLD for the Offset of a line.
> So my workaround is SLD with NamedStyle - I copied the Classes and the
> first are in group1 the last in group2. I switch in the one layer with
> the name of the group.
> So my question is - is it possible to use UserStyle SLD with the
> possibility to set a usefull offset or could the offset in the mapfile
> could be used even if nothing more is defined in the SLD.
> Thanks for your support/ideas.
> BR,
> Hannes
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: yassefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110414/8113ee42/attachment.html
