[mapserver-users] Mapserver and raster layers
Christopher Dedels
cdedels at gmail.com
Sat Apr 16 14:22:13 EDT 2011
I am having some problems adding a raster layer to my map. The image
produced by mapserver is blank. My mapfile is as follows:
MAP
SIZE 800 600
UNITS meters
EXTENT -123.8600311 38.0116386 -97.1885986 53.7055626
PROJECTION
"+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
END
LAYER
NAME "grid"
TYPE RASTER
DATA "/tmp/image.tiff"
STATUS ON
PROJECTION
END
END
END
I have also noticed that changing the DATA path to a file which does not
exist in the filesystem (or is not a GDAL-supported file format) has no
effect on the rendered output and does not produce an error message.
Can somebody help me where I am going wrong?
Thanks
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110416/4100903d/attachment.html
