[mapserver-users] Mapserver and raster layers
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Sat Apr 16 16:43:34 EDT 2011
- Add DEBUG 5 into your LAYER and see what you'll get into MS_ERRORFILE
- What kind of request do you use for getting an image?
- Using full paths into your image file may help
- Send also the gdalinfo output of image.tiff file
-Jukka Rahkonen-
> Christopher Dedels
> Thanks for the suggestion. I have tried it and it appears to have no
> effect.
>Chris
On Sat, Apr 16, 2011 at 4:26 PM, Stephen Woodbridge <woodbri at swoodbridge.com
>> wrote:
>> Try changing the layer status to default, ie:
> STATUS DEFAULT
> -Steve W
> On 4/16/2011 2:22 PM, Christopher Dedels wrote:
>> I am having some problems adding a raster layer to my map. The image
>> produced by mapserver is blank. My mapfile is as follows:
>> MAP
>> SIZE 800 600
>> UNITS meters
>> EXTENT -123.8600311 38.0116386 -97.1885986 53.7055626
>> PROJECTION
>> "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs"
>> END
>> LAYER
>> NAME "grid"
>> TYPE RASTER
>> DATA "/tmp/image.tiff"
>> STATUS ON
>> PROJECTION
>> END
>> END
>> END
>> I have also noticed that changing the DATA path to a file which does not
>> exist in the filesystem (or is not a GDAL-supported file format) has no
>> effect on the rendered output and does not produce an error message.
>> Can somebody help me where I am going wrong?
>> Thanks
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
