[mapserver-users] MS 6.0 beta6 and faulty image/png; mode=8bit
output if source image has overviews
thomas bonfort
thomas.bonfort at gmail.com
Tue Apr 19 03:39:26 EDT 2011
please test with trunk and report back if you're still having the
error: http://trac.osgeo.org/mapserver/ticket/3848
thomas
On Tue, Apr 19, 2011 at 09:32, Erik Gustafson <gustafson.erik at gmail.com> wrote:
>> On Mon, Apr 18, 2011 at 10:18, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
>>> Hi,
>>> I am sometimes getting images with totally odd colours with MS 6.0 beta 6
>>> (and the previous beta versions) with format image/png; mode=8bit. I have
>>> been doing some testing and I believe I can now reproduce the error.
>>> The error happens only if the raster image has overviews. If I delete or
>>> rename the external .ovr file the 8bit png output is correct at any scales.
>>> To be sure that there is nothing odd with the overview file I recreated it
>>> with FWTools v. 2.4.2 by using a basic command
>>> gdaladdo -r average -ro suomi1m.tif 2 4 8
> [snip]
>>> My conclusion is that exectly MS 6.0 version is creating at some scales
>>> through ADD driver an 8 bit png output with messed up colours, but it
>>> happens only if the source image has overviews.
>>> If someone is interested in having a look at this I can prepare and send my
>>> mapfile and some imagery to play with.
>>> -Jukka Rahkonen-
> Hello, I have a similar problem on vector data, possibly related.
> The color problem appears when quantize is enabled and a large amount
> if data is rendered. I can trigger the bug with mapfile below:
> MAP
> OUTPUTFORMAT
> NAME "png"
> DRIVER "agg/png"
> FORMATOPTION QUANTIZE_FORCE=on
> END
> LAYER
> NAME corine
> DATA "corine"
> TYPE polygon
> CLASS
> NAME ALL2
> EXPRESSION ([area_ha] < 1000)
> STYLE
> COLOR 0 0 255
> END
> END
> CLASS
> NAME ALL
> EXPRESSION ([area_ha] < 1500)
> STYLE
> COLOR 255 0 0
> END
> END
> CLASS
> NAME ALL
> #EXPRESSION ([area_ha] < 1500)
> STYLE
> COLOR 0 255 0
> END
> END
> END
> END
> To trigger the bug I need at least two classes with different colors.
> If I use a single color or if I render only a subset of the data the
> colors look good. I do not have a test case yet as the data used is
> not free. I will try to create one but it might take a few days. Just
> writing this to note that problem may not be related to the overviews
> but the quantizing itself.
> Another note: If I add and OUTLINECOLOR and WIDTH=1 in the style
> definition the problem seems heal the bug, I guess thats because fewer
> antialiasing colors are generated.
> No problem with this mapfile on Mapserver 5.6.
> /Erik
> mapserver-users at lists.osgeo.org
