[mapserver-users] Mapserver6 calls exit() in FastCGI-mode
Frank Warmerdam
warmerdam at pobox.com
Wed Apr 20 10:56:43 EDT 2011
On 11-04-20 03:59 AM, Erik Gustafson wrote:
> The problem is that the error from Mapserver 6, apart from its user
> unfriendlyness for ows-requests, is reported by writeError() in
> mapserv.c which calls exit() even if we are running under FastCGI. As
> this error is non fatal I consider this a bug.
Erik,
For reference, I do *not* consider this a bug. In my opinion it is
perfectly acceptable for MapServer processes to terminated sometimes on
an error even when running in FastCGI mode. Reasonable FastCGI
implementations will just start a new process for the next request so
the only harm is a slight delay as libraries are reinitialized and
DB connections are re-established.
The error you are encountering is not something that will happen often
in practice.
In fact, I believe it is a good practice to have MapServer FastCGI
instances recycled occasionally as it is hard to ensure there are
no memory leaks in the more esoteric parts of the code.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
