[mapserver-users] Problems with png output when using libpng 1.5
Christy Nieman
cnieman at dmsolutions.ca
Thu Apr 21 08:59:45 EDT 2011
Thomas,
Sorry it took me awhile to respond - I'd left things compiling when I
went home last night, and it failed, so I had to fix it and get it going
again this morning. With libpng 1.5.3 beta3 and mapserver 6.0 beta 7
(since it was released before I fixed things this morning), everything
now seems fine.
Christy
On 04/21/2011 04:59 AM, thomas bonfort wrote:
> Christy,
> Can you confirm that the bug disappeared with the latest libpng beta ?
> thomas
> On Wed, Apr 20, 2011 at 16:39, Christy Nieman<cnieman at dmsolutions.ca> wrote:
>> Aha, thanks Thomas. I hadn't found that.
>> On 04/20/2011 10:28 AM, thomas bonfort wrote:
>>> Christy,
>>> I suspect this is due to a bug in libpng. see
>>> http://sourceforge.net/tracker/index.php?func=detail&aid=3288207&group_id=5624&atid=105624
>>> On Wed, Apr 20, 2011 at 15:20, Christy Nieman<cnieman at dmsolutions.ca>
>>> wrote:
>>>> Hi,
>>>> I compiled MapServer 6.0 beta6 against libpng 1.5.2 and encountered the
>>>> following problems:
>>>> when using the default png IMAGETYPE (i.e. no OUTPUTFORMAT block), I got
>>>> yellow& striped maps (see cyprus.png)
>>>> when using the AGG/PNG driver and IMAGEMODE "RGBA", the output image
>>>> looks
>>>> fine
>>>> when using the default png8 IMAGETYPE, the output image looks fine
>>>> I also compiled with cairo, and with the driver set to CAIRO/PNG, I had
>>>> the
>>>> same yellow& striped maps.
>>> rgba and png8 use different png formats. agg/png and cairo/png use the
>>> same codepath when saving images, so the behavior your are observing
>>> is normal.
>>>> With libpng 1.2.44, everything seems to work properly. Has anyone else
>>>> seen
>>>> this problem with libpng 1.5? Should it work properly with MapServer?
>>>> Regards,
>>>> Christy
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
