[mapserver-users] Re: [mapserver-dev] problem with mapserver
thomas bonfort
thomas.bonfort at gmail.com
Thu Apr 21 13:05:15 EDT 2011
you create it, it maps font names, used with the LABEL->FONT keyword,
with the full path to your .tff font.
e.g.
arial /usr/local/share/fonts/arial.ttf
arialbold /usr/local/share/fonts/arialbf.ttf
this is all in the docs... http://mapserver.org/mapfile/fontset.html
http://mapserver.org/mapfile/label.html
On Thu, Apr 21, 2011 at 18:52, Annabell Schelton Lima <aschelton at uci.cu> wrote:
> thanks Thomas, i already checked the location of the font file and does not found it, there is not a file fonts.list in my project, so, what can i do? where can i get this file?
> ----- Mensaje original -----
> De: "thomas bonfort" <thomas.bonfort at gmail.com>
> Para: "Annabell Schelton Lima" <aschelton at uci.cu>
> CC: "MapserverList OSGEO" <mapserver-users at lists.osgeo.org>
> Enviados: Jueves, 21 de Abril 2011 18:22:25 GMT +01:00 Amsterdam / Berlín / Berna / Roma / Estocolmo / Viena
> Asunto: Re: [mapserver-dev] problem with mapserver
> please keep the message on list.
> this is usually the case if the font file (referenced from your
> fontset) was corrupt or pointing to an incorrect location.
> On Thu, Apr 21, 2011 at 17:57, Annabell Schelton Lima <aschelton at uci.cu> wrote:
>> i tried it that before, but does not work, when i use type truetype in my object label my label layer does not show..any idea??
>> Enviados: Jueves, 21 de Abril 2011 17:47:23 GMT +01:00 Amsterdam / Berlín / Berna / Roma / Estocolmo / Viena
>> forwarding this to the mapserver-users list where it belongs.
>> you are setting TYPE bitmap, which does not support more than ascii characters.
>> you must set TYPE TRUETYPE and SIZE 9 (an integer value, not tiny,
>> medium, etc...)
>> regards,
>> thomas
>> On Thu, Apr 21, 2011 at 16:35, Annabell Schelton Lima <aschelton at uci.cu> wrote:
>>> hi, i have a problem with encoding labels and mapfile configuration..my data is already converted to UTF-8 format, stored in a postgres database, but the labels do not recognize the accents, this is my mapfile in the section label, i declare it like a new layer with annotations, but as a part of a layer with labelitem the result it´s the same...
>>> LABEL
>>> SIZE medium
>>> FONT arial
>>> COLOR 0 0 0
>>> POSITION cl
>>> TYPE bitmap
>>> ANTIALIAS TRUE
>>> MINDISTANCE 300
>>> #MINFEATURESIZE 200
>>> ENCODING "UTF-8"
>>> BUFFER 4
>>> PARTIALS FALSE
>>> END
>>> Please, somebody help me, i really need resolve this soon...
>>> mapserver-dev mailing list
>>> mapserver-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
