[mapserver-users] adding ecw support
Jackson, John
jxjackso at franklincountyohio.gov
Mon Apr 25 13:04:24 EDT 2011
Debug 5 produces:
[Mon Apr 25 12:00:04 2011].97972 msDrawRasterLayerLow(ortho): entering.
[Mon Apr 25 12:00:04 2011].98406 drawEPP(): Image handling error. EPPL7 support is not available.
[Mon Apr 25 12:00:04 2011].98414 msDrawRaster(): Image handling error. Unrecognized or unsupported image format
[Mon Apr 25 12:00:04 2011].98421 msDrawMap(): Image handling error. Failed to draw layer named 'ortho'.
relevant section from map file is pretty straightforward:
LAYER
NAME "ortho"
STATUS on
TYPE RASTER
DATA "/home/ecw/test.ecw"
END
________________________________________
Sent: Monday, April 25, 2011 12:59 PM
To: Jackson, John
Subject: Re: [mapserver-users] adding ecw support
Try setting DEBUG 5 and CONFIG MS_ERRORFILE '/var/www/error.log' into the MAP section to see what does
Mapserver throws.
Also, can you post the MAP file contents ?
Cheers from México
IC Carlos Ruiz
From: "Jackson, John" <jxjackso at franklincountyohio.gov>
To: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Sent: Monday, April 25, 2011 11:25 AM
Quick question:
I've compiled libecw3.3 and gdal... now gdalinfo --formats shows the ECW format, but mapserver still won't produce a map with an ecw file.
Do I need to recompile mapserver also?
(I'm running 5.65 on a Fedora 13 box if that helps)
Thanks
--John Jackson
--Deputy Auditor
--jxjackso at franklincountyohio.gov<mailto:--jxjackso at franklincountyohio.gov>_______________________________________________
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
