[mapserver-users] multiple styles in a class
Mukesh Subedee
msubedee at yahoo.com
Wed Apr 27 16:50:16 EDT 2011
I wanted to minimize the number of classes within a layer and found a statement
in MapServer/Style documentation that we can have multiple styles within a class
but was wondering if they could be used for styling (coloring) different
attributes of a type (as in PIG example).
Mukesh
From: "Fawcett, David (MPCA)" <david.fawcett at state.mn.us>
To: Mukesh Subedee <msubedee at yahoo.com>; mapserver mailing list
<mapserver-users at lists.osgeo.org>
Sent: Wednesday, April 27, 2011 13:42:58
Subject: RE: [mapserver-users] multiple layers in a class
No. That is what classes are for.
What is your concern about using multiple classes?
Sent: Wednesday, April 27, 2011 3:41 PM
To: Fawcett, David (MPCA); mapserver mailing list
Subject: Re: [mapserver-users] multiple layers in a class
Oops, my bad...I meant multiple styles within a class. Does that mean I cannot
use different color scheme for symbolizing "SMALL PIG" and "BIG PIG" within a
same class? Is there any way to categorize each PIG with different EXPRESSION
and give different STYLE for each within a class?
Mukesh
From:"Fawcett, David (MPCA)" <david.fawcett at state.mn.us>
Sent: Wednesday, April 27, 2011 12:35:44
Mukesh,
If you want to symbolize SMALL PIG and BIG PIG differently, you will need two
classes. A class is used to select features that match the (optional) class
expression.
You can have multiple styles within a class, but they would be applied equally
to all of the features in that class. One example might be stacking symbols for
a feature.
The docs don’t say that you can have multiple ‘layers’ within a class, but that
you can have multiple ‘styles’ applied within a class.
http://mapserver.org/mapfile/style.html
In your description below, you are conceptually talking about having different
classes within a layer, but just using different words. Is there a reason that
you have an aversion to using multiple classes?
You can group classes if there is a need for it.
http://mapserver.org/mapfile/class.html
David.
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Mukesh Subedee
Sent: Wednesday, April 27, 2011 2:06 PM
To: mapserver mailing list
Subject: [mapserver-users] multiple layers in a class
In the STYLE documentation, it is mentioned that it is possible to have multiple
layers within a class. I could not find any example how it can be implemented. I
was checking an example
in http://lists.osgeo.org/pipermail/mapserver-users/2010-August/066303.html where
"SMALL PIG" and "BIG PIG" are in two different classes. However I am wondering
if it is possible to implement it within a same class but representing with
different styles. It means representing two different "PIG" in a same class but
with different coloring mechanisms.
Thanks,
Mukesh
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110427/e06686be/attachment.html
