[mapserver-users] character encoding shape file with german umlaute
karsten vennemann
karsten at terragis.net
Thu Apr 28 03:55:26 EDT 2011
Hi List,
I had some trouble with getting correct character encoding to work with MapServer and with german Umlauten (ÄÜÖ and ß).
For a PostGIS layer I got it fixed setting the permanent variable 'client encoding' to LATIN1 does the trick ;) The db otherwise is utf8 , the system german locale (which has impact really anyway for he most part).
However I have now trouble also with labels from a shape file based MapServer WMS which show screwed up as some symbols . The attributes are showing correctly inside the dbf table. The same layers just 'worked' on the old server - however something must be different on the new one since that is just came up with the move. Is there anything I can look for to coax MapServer to correctly encode label test annotations ?
I tried setting
ENCODING 'LATIN1'
in the label to no avail ..
Cheers
Karsten
Terra GIS LTD
www.terragis.net
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110428/bccc4ee9/attachment.html
