[mapserver-users] Re: NoDATA value,
transparency for paletted IMG file
ChrisFern
yrrman at gmail.com
Thu Apr 28 06:42:46 EDT 2011
Dear Frank, dear all,
thanks for your reply.
I think I have narrowed down the problem and it isn't really a mapserver
issue - the 8bit paletted img gets rendered to a 4bit-per-pixel png whereas
the correctly transparent RGB img gets rendered to an 8bit-per-pixel png.
Seems that the Google Earth API can't detect/deal with the NoData value in
this 4bpp png and renders this value sort of "shaded black" (which I would
like to get ridd of). GIMP for example can deal with the transparency in
this 4bpp png.
If I switch to RGBA in the output format, then I have the transparency
however the image is much bigger:
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
# IMAGEMODE RGBA
IMAGEMODE PC256
EXTENSION "png"
TRANSPARENT ON
FORMATOPTION "transparent=on"
END
Is there a way I can force the mapserver to produce 8bpp pngs?
THANKS for your help - highly appreciated - and greetings,
Chris
PS here's the gdalinfo output for the 4bpp png:
Driver: PNG/Portable Network Graphics
Files: lb_usa.png
Size is 1024, 768
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 768.0)
Upper Right ( 1024.0, 0.0)
Lower Right ( 1024.0, 768.0)
Center ( 512.0, 384.0)
Band 1 Block=1024x1 Type=Byte, ColorInterp=Palette
NoData Value=0
Image Structure Metadata:
NBITS=4
Color Table (RGB with 9 entries)
0: 1,1,1,0
1: 0,0,0,255
2: 12,16,120,255
3: 31,62,140,255
4: 33,110,158,255
5: 42,156,154,255
6: 61,184,104,255
7: 59,214,45,255
8: 113,235,47,255
View this message in context: http://osgeo-org.1803224.n2.nabble.com/NoDATA-value-transparency-for-paletted-IMG-file-tp6305135p6312790.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
