[mapserver-users] Re: JPG Tile index in mapserver v5.6.3
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Apr 28 08:21:03 EDT 2011
Jpeg file format is not good for a typical geospatial use when a little arbitrary piece of a big image should be opened and showed.
I forgot one tiff creation option, use -co TILED=YES
That way you can create a tiff image file which is internally organised as tiles which are fast to fetch without a need to read the whole big image file. The image data inside tiff can be compressed with jpeg algorithm which will give the same level of compression than using plain jpeg files.
When it comes to your original ecw files and the jpeg files you have now in your hands, forward systematically.
- check the original ecw with gdalinfo
gdalinfo original.ecw
- compare with the gdalinfo or the jpeg file
- you should want to check the tileindex shapefile with some GIS program like OpenJUMP or QGis; check if the image footprint rectangles are there nice and if the LOCATION attribute has some reasonable value; consider running gdaltindex with -write_absolute_path if you are not sure about where the relative paths will lead
- check the projections in your mapfile, both at MAP and LAYER level
- add DEBUG 5 into your layer and read what you will get into MS_ERRORFILE
- I trust that you will get your images shown and that you will easily find lots of interesting reading about the topic from the web.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> marten.martinsson
> Lähetetty: 28. huhtikuuta 2011 15:04
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Re: JPG Tile index in mapserver v5.6.3
> Hi Jukka!
> I already tried to change the file ending on the world file
> but it didn´t
> help.
> Not really with you on yor 2nd tip there.
> You want me to convert the jpg to tiff-files instead?
> I am pretty new to GDAL so could you explain what the
> functions actually
> does?
> /M
> http://osgeo-org.1803224.n2.nabble.com/JPG-Tile-index-in-mapse
rver-v5-6-3-tp6312908p6312963.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
