[mapserver-users] Validation example wanted
thomas bonfort
thomas.bonfort at gmail.com
Fri Apr 29 04:39:51 EDT 2011
have you tried without the surrounding slashes? i.e.
VALIDATION
tag "."
value "."
END
On Fri, Apr 29, 2011 at 10:37, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> Could somebody tell how can I make my WMS requests to validate? I am sending WMS GetMaps with two extra parameters "tag" and "value" by adding them to the end of the request like &tag=amenity&value=supermarket.
> Tag and value can be anything and they should be used inside the following LAYER-DATA
> DATA "way from (select (way),osm_id,tags from osm_point where (tags @>'%tag%=>%value%')) as foo using unique osm_id using srid=3067"
> I have tried to put a validation block in LAYER
> VALIDATION
> tag "/./"
> value "/./"
> END
> I have also tried to add these two lines into WEB-METADATA
> tag_validation_pattern "/./"
> value_validation_pattern "/./"
> Because I am here you can guess that my trials were not successful.
> I am using MS 6.0 beta7. Queries with tag and value worked with 5.6.1 version.
> -Jukka Rahkonen-
> mapserver-users at lists.osgeo.org
