[mapserver-users] Parameterized MapFile using CGI variable
Nicolas BOUTET
nicolas.boutet at geosys.com
Fri Apr 29 10:49:13 EDT 2011
Thank you David,
Yes, using INCLUDE should be a good solution. But as I know in MapServer
5.6, CONNECTION is a parameter of my LAYER objects, and not an object
itself. So I cannot have a CONNECTION object declared in a separate map
file
And I prefer to not have to duplicate the layers in different map
files.
Nicolas
De : Fawcett, David (MPCA) [mailto:david.fawcett at state.mn.us]
Envoyé : vendredi 29 avril 2011 16:37
À : nicolas.boutet at geosys.com; mapserver-users at lists.osgeo.org
Objet : RE: [mapserver-users] Parameterized MapFile using CGI variable
One potential way to do it would be with the use of includes.
http://mapserver.org/mapfile/Include.html
The primary mapfile wouldnt have a connection object, but it would contain:
INCLUDE connect_info.map
Then on each machine, you would have a different version of connect_info.map
that contained the correct connection object for that machine.
This wouldnt give you the flexibility of changing it through the CGI
interface, but would allow you to use the same exact mapfile on both
machines.
David.
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Nicolas BOUTET
Sent: Friday, April 29, 2011 8:57 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Parameterized MapFile using CGI variable
Dear All,
I have 2 MapServer servers. One for Production use, and the other for
Validation use.
The MAP files placed on those servers are similar except that each server
has a different Oracle database as datasource.
For now, I have some different CONNECTION values depending if the map file
is on the Production or on the Validation server. So finally I must have
different MAP files.
Is there a way to have exactly the same map files on the 2 servers, and to
use a variable to parameterize the CONNECTION.
For example, I would like to set the CONNECTION of my layers to
%ORACLECONNECTIONSTRING% and to set a CGI Environment variable named
ORACLECONNECTIONSTRING to the correct value on each server.
Nicolas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110429/69458558/attachment-0001.html
