[mapserver-users] Parameterized MapFile using CGI variable
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Apr 29 11:54:35 EDT 2011
No problem at all. I have it this way
For each layer
LAYER
STATUS ON
GROUP "default"
PROJECTION
"init=epsg:3067"
END
INCLUDE "/usr/map/connection_osm_i.map"
maxscaledenom 500010
minscaledenom 250010
TYPE LINE
NAME "roadsclose"
DATA "way from (select way, osm_id ,highway,ref, name, tunnel from osm_line where highway is not null order by priority desc) as foo using unique osm_id using srid=3067"
And the "/usr/map/connection_osm_i.map" file is
CONNECTIONTYPE postgis
CONNECTION "host=localhost dbname=xxx user=yyy password=zzz port=5432"
PROCESSING "CLOSE_CONNECTION=DEFER"
Helps a lot when changing something on the database side also because there is only one place to update in the mapfiles.
-Jukka Rahkonen-
-----Alkuperäi
nen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Nicolas BOUTET
Lähetetty: pe 29.4.2011 17:49
Vastaanottaja: 'Fawcett, David (MPCA)'; mapserver-users at lists.osgeo.org
Aihe: RE: [mapserver-users] Parameterized MapFile using CGI variable
Thank you David,
Yes, using INCLUDE should be a good solution. But as I know in MapServer
5.6, CONNECTION is a parameter of my LAYER objects, and not an object
itself. So I cannot have a CONNECTION object declared in a separate map
file. And I prefer to not have to duplicate the layers in different map
files.
Nicolas
De : Fawcett, David (MPCA) [mailto:david.fawcett at state.mn.us]
Envoyé : vendredi 29 avril 2011 16:37
À : nicolas.boutet at geosys.com; mapserver-users at lists.osgeo.org
Objet : RE: [mapserver-users] Parameterized MapFile using CGI variable
One potential way to do it would be with the use of 'include's.
http://mapserver.org/mapfile/Include.html
The primary mapfile wouldn't have a connection object, but it would contain:
INCLUDE "connect_info.map"
Then on each machine, you would have a different version of connect_info.map
that contained the correct connection object for that machine.
This wouldn't give you the flexibility of changing it through the CGI
interface, but would allow you to use the same exact mapfile on both
machines.
David.
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Nicolas BOUTET
Sent: Friday, April 29, 2011 8:57 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Parameterized MapFile using CGI variable
Dear All,
I have 2 MapServer servers. One for Production use, and the other for
Validation use.
The MAP files placed on those servers are similar except that each server
has a different Oracle database as datasource.
For now, I have some different CONNECTION values depending if the map file
is on the Production or on the Validation server. So finally I must have
different MAP files.
Is there a way to have exactly the same map files on the 2 servers, and to
use a variable to parameterize the CONNECTION.
For example, I would like to set the CONNECTION of my layers to
"%ORACLECONNECTIONSTRING%" and to set a CGI Environment variable named
ORACLECONNECTIONSTRING to the correct value on each server.
Nicolas
