[mapserver-users] free() methods in MapScript, compatibility
MS 5.x and 6
Armin Burger
armin.burger at gmx.net
Fri Apr 29 13:40:42 EDT 2011
Alan
I used a script creating 3 different type of objects without applying
the "free" method, put it in a loop with 1M cycles and opened it in a
browser. Checking the memory usage of the Apache process while running
the script showed no increase of memory at all. So I would guess the
free() is not needed any more. Test was made with MS 5.6
Armin
On 29/04/2011 15:13, Alan Boudreault wrote:
> Hi Armin,
> Although I'm not sure if the free call was useful... since it was only
> removing the php object from a global list but the object was not really freed
> until the end of the script... I would suggest to simply add a such condition
> "if ms_version< 6 ... obj->free()" rather than removing them to be compatible
> 5.6/6.0 and avoid any issue. You can also do a quick test in your script with
> some echo of the memory used before the end of the script and see if the
> free() removal has any effect.
> Alan
> On April 27, 2011 01:25:54 pm Armin Burger wrote:
>> Hi everybody
>> in MapServer/MapScript 6 the various class methods "free()" have been
>> removed. If I want to have PHP/MapScript code compatible with both
>> MapServer 5.x and 6, the easiest would be to completely remove these
>> method calls from the code.
>> My question is just if these free() methods are still somehow required
>> or recommended for MapServer/MapScript 5.x or if I can silently drop
>> them without any drawbacks.
>> Cheers
>> Armin
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
