[mapserver-users] WFS Spatial Filter Problem
Julien Cigar
jcigar at ulb.ac.be
Wed Aug 10 08:44:45 EDT 2011
Perhaps the problem comes from the HTTP server (wrong (Fast)CGI config,
...) ? Take a look at your your error.log
On 08/10/2011 14:35, Bryan Hempen wrote:
> Hi David,
> I enabled debugging using the following settings:
> CONFIG "MS_ERRORFILE" "/home/bhempen/ms_error.txt"
> DEBUG 5
> CONFIG "CPL_DEBUG" "ON"
> CONFIG "PROJ_DEBUG" "ON"
> The only line that shows up after I got an error 500 using the spatial
> filter is:
> [Wed Aug 10 14:30:46 2011].451858 CGI Request 1 on process 21100
> Not really helpful, right?
> Regards,
> Bryan
> On 09/08/2011 15:38, Fawcett, David (MPCA) wrote:
>> Bryan,
>> For testing, I would enable debugging at the MAP or LAYER level. If
>> you set DEBUG 5, I think that you should be able to see the query that
>> MapServer is crafting.
>> More on debugging here:
>> http://mapserver.org/optimization/debugging.html#debugging
>> David.
>> *From:*mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Bryan
>> Hempen
>> *Sent:* Tuesday, August 09, 2011 4:15 AM
>> *Cc:* mapserver-users at lists.osgeo.org
>> *Subject:* Re: [mapserver-users] WFS Spatial Filter Problem
>> Dear Kai and Assefa,
>> After you two guys requested me to send you my setup, I exported the
>> content in the databasetable to a shapefile so you can test it. When I
>> tested the spatial filter right after that, it suddenly worked ! This
>> narrows down the possibilities:
>> - The request I send is definitely not the problem anymore. It works
>> with MapServer + shapefile and with GeoServer.
>> - I exported only the geometries to the shapefile in the table with
>> geometrytype = POLYGON because from ~8000 geometries ~10 are
>> linestrings. So I investigated possible problems with the linestring
>> geometries by telling the MapServer not to serve them using a subquery
>> in the mapfile:
>> DATA "the_geom from (select * from alldata where
>> geometrytype(the_geom) = 'POLYGON') as subquery using unique
>> product_id using SRID=4326"
>> Error 500 still occured. Therefore, the data can't be the problem
>> neither, right?
>> - Since I didn't change anything else MapServer must have problems
>> communicating with the PostGIS database, but why Error 500 then?
>> Here is my mapfile:
>> MAP
>> NAME "WFS Server"
>> STATUS ON
>> SIZE 600 400
>> SYMBOLSET
>> "/var/www/html/psa/bhempen/mapservertest/symbols/symbols.sym"
>> EXTENT -180 -90 180 90
>> UNITS DD
>> SHAPEPATH "/var/www/html/psa/bhempen/mapservertest/data/"
>> IMAGECOLOR 255 255 255
>> FONTSET "/var/www/html/psa/bhempen/mapservertest/fonts/fonts.list"
>> MAXSIZE 4096 # needs to be set because otherwise an error will
>> appear when rendering images on large screens
>> #IMAGECOLOR 200 200 200 #commented out for WFS
>> PROJECTION
>> 'init=epsg:4326'
>> END
>> WEB
>> TEMPLATE '/var/www/html/psa/bhempen/mapservertest/template.html'
>> IMAGEPATH '/var/www/html/psa/bhempen/tmp/'
>> IMAGEURL '/psa/bhempen/tmp/'
>> METADATA
>> "wfs_title" "WFS Demo Server for
>> MapServer" ## REQUIRED
>> "wfs_onlineresource"
>> "http://localhost/cgi-bin/psa/mapserv?map=/home/bhempen/wfs.map&"
>> <http://localhost/cgi-bin/psa/mapserv?map=/home/bhempen/wfs.map&> ##
>> Recommended
>> "wfs_srs" "EPSG:4326" ## Recommended
>> "wfs_abstract" "This text describes my WFS
>> service." ## Recommended
>> END
>> END
>> LAYER
>> NAME "omega"
>> STATUS DEFAULT
>> TYPE POLYGON
>> METADATA
>> "wfs_title" "omega footprints" ##REQUIRED
>> "wfs_srs" "EPSG:4326" ## REQUIRED
>> "gml_include_items" "all" ## Optional (serves all
>> attributes for layer)
>> "gml_featureid" "product_id" ## REQUIRED
>> END
>> PROJECTION
>> "init=epsg:4326"
>> END
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "host=localhost port=xxx dbname=xxx user=xxx password=xxx"
>> DATA "the_geom from alldata using unique product_id using SRID=4326"
>> CLASS
>> STYLE
>> OUTLINECOLOR 125 0 0
>> END
>> END
>> DUMP TRUE ## REQUIRED
>> END # layer
>> END
>> Does anyone see a problem with the setup?
>> Many thanks to Kai and Assefa for the help so far! I am going to send
>> you the shapefile (which you could import into the database with
>> pgsql2shp), the mapfile, and my client.
>> Kind regards,
>> Bryan
>> This message and any attachments are intended for the use of the addressee or addressees only. The unauthorised disclosure,
>> use, dissemination or copying (either in whole or in part) of its content is not permitted. If you received this message in
>> error, please notify the sender and delete it from your system. Emails can be altered and their integrity cannot be guaranteed by
>> the sender.
>> Please consider the environment before printing this email.
> the sender.
No trees were killed in the creation of this message.
However, many electrons were terribly inconvenienced.
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110810/508d612b/jcigar.vcf
