[mapserver-users] Cluster in mapserver
Ludovic Granjon
ludovic.granjon at u-bourgogne.fr
Fri Aug 12 03:13:58 EDT 2011
Hello
I use mapserver with a cluster in a point layer.
I use Cluster:FeatureCount in the size parameter :
CLASS
NAME "test"
STYLE
COLOR 255 0 0
SYMBOL 'circle'
SIZE [Cluster:FeatureCount]
END # Style
END # Class
It work fine, but I have two problems :
First I'd like to have a size like [Cluster:FeatureCount]+10 or
something like that, but it doesn't work, maybe I miss something. Do you
know if it's possible ?
Second, I want to get back the legend, but in the legend I have only the
minimum value of the cluster, is there a way to get back also the
maximum value of the cluster ?
If it's better, I can use mapscript to do that.
Thanks all
Ludovic
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110812/f7264910/ludovic_granjon.vcf
