[mapserver-users] Invalid pdf file from WMS
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Aug 18 03:25:35 EDT 2011
I believe I istalled Mapserver by doing something like
sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
sudo apt-get update
sudo apt-get install cgi-mapserver mapserver-bin
If I can upgrade cairo, it depends on what you mean with "can" :) I have enough rights for the server to do it but I have used very very little Linux and do not know how to do it. But I am able to copy provided commands like in the successful gdb case.
-Jukka Rahkonen-
thomas bonfort wrote:
> this seems to be a cairo/pdf issue, as the cairo/png works fine:
> http://188.64.1.61/cgi-bin/osm-mapserver_i?REQUEST=GetMap&SERV
ICE=WMS&VERSION=1.1.1&WIDTH=1728&HEIGHT=1324> &LAYERS=default&TRANSPARENT=TRUE&FORMAT=cairopng&BBOX=3409763.
750050978,6956187.032331026,3411904.266676571,6957827.104097395> &SRS=EPSG:2393&STYLES=
> what cairo version are you using? can you upgrade it?
> thomas
> On Wed, Aug 17, 2011 at 22:46, Rahkonen Jukka
> <Jukka.Rahkonen at mmmtike.fi> wrote:
> > Hi,
> > Amazing. I got this
> > (gdb) bt
> > #0 0x0013a258 in FT_Done_Face () from /usr/lib/libfreetype.so.6
> > #1 0x00f447c3 in ?? () from /usr/lib/libcairo.so.2
> > #2 0x00f4ba19 in cairo_font_face_destroy () from
> > #3 0x0813a8b4 in ?? ()
> > #4 0x0813a9c8 in cleanupCairo ()
> > #5 0x080c5aee in ?? ()
> > #6 0x0810b406 in ?? ()
> > #7 0x0807207d in ?? ()
> > #8 0x0805c2f4 in ?? ()
> > #9 0x00fefbd6 in __libc_start_main () from
> /lib/tls/i686/cmov/libc.so.6
> > #10 0x08057881 in ?? ()
> > -Jukka-
> > ________________________________________
> > Lähettäjä: thomas bonfort [thomas.bonfort at gmail.com]
> > Lähetetty: 17. elokuuta 2011 22:56
> > Vastaanottaja: Rahkonen Jukka
> > Kopio: mapserver-users at lists.osgeo.org
> > Aihe: Re: [mapserver-users] Invalid pdf file from WMS
> > if gdb is installed on the system, you do:
> > gdb /path/to/mapserv
> > $ run QUERY_STRING='map=...&....'
> > (...program runs and spits out the beginning of the pdf...,
> then segfaults)
> > $ bt
> > thomas
> > On Wed, Aug 17, 2011 at 21:36, Rahkonen Jukka
> >> Hi,
> >> Command with big BBOX does lead into segmantation fault.
Unfortunately I am just an amateur and I have no idea about what is > a backtrace and how I could provide it to you. The server is
> a virtual Linux box (Ubuntu).
> >> -Jukka Rahkonen-
> >>> the second one is incomplete, the request seems to be failing.
> >>> can you run the request locally to see if it segfaults, and if so
> >> provide a backtrace:
> >>> /path/to/mapserver-cgi
> QUERY_STRING='map=/path/to/map&REQUEST=GetMap&SERVICE=WMS&VERS
> ION=1.1.1&WIDTH=864&HEIGHT=662&LAYERS=default&TRANSPARENT=TRUE
&FORMAT=application/x-pdf&BBOX=> 3409763.750050978,6956187.032331026,3411904.266676571,6957827.
> 104097395&SRS=EPSG:2393&STYLES='
> >> thomas
> >> On Wed, Aug 17, 2011 at 15:40, Rahkonen Jukka
> >>> Hi,
> >>>> This request from Mapserver 6.0 gives me a nice pdf file:
ICE=WMS&VERSION=1.1.1&WIDTH=864&HEIGHT=662> &LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BBOX
> =3409763.750050978,6956187.032331026,3411904.266676571,6957827
> .104097395&SRS=EPSG:2393&STYLES=
> >>> However, if I double the bounding box the resulting pdf
> cannot be opened by Acrobat reader.
ICE=WMS&VERSION=1.1.1&WIDTH=1728&HEIGHT=1324> &LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BBOX
> >>> The latter gives fine image with format=image/png. Any
> idea about what is going wrong?
> >>> -Jukka Rahkonen-_______________________________________________
> >>> mapserver-users mailing list
> >>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
