[mapserver-users] XML mapfile
Alan Boudreault
aboudreault at mapgears.com
Fri Aug 19 08:20:07 EDT 2011
IIRC, the mapfiles in svn were only to test translation and loading. You can
take a small standard mapfile you have and write it in xml. It should be very
straighforward and you can use the svn mapfiles as example.
Let me know if you need further help.
Alan
On August 19, 2011 07:42:17 am Ludovic Granjon wrote:
> Hello
> Someone is using mapfiles in xml?
> I tried but it does not work, is there such a minimal mapfile in xml to
> try? Is there a documentation ? I tried unsuccessfully
> http://trac.osgeo.org/mapserver/browser/trunk/mapserver/xmlmapfile
> Thanks
> Ludovic
