[mapserver-users] XML mapfile
Ludovic Granjon
ludovic.granjon at u-bourgogne.fr
Fri Aug 19 08:40:39 EDT 2011
Thanks Alan
Yes that's what I try to do but when I try to launch xmlstarlet I always
have an invalid mapfile;
for exemple I join my mapfile
And the message of xmlstartlet is :
"mapfile-test_ludo.xml:69: element LayerSet: Schemas validity error :
Element '{http://www.mapserver.org/mapserver}LayerSet': This element is
not expected. Expected is ( {http://www.mapserver.org/mapserver}Web )."
If I delete the LayerSet bloc it's ok but it's annoying ...
If I try with my very little mapfile.map, it seems that it always miss
some bloc so I must insert legend, scalebar, etc
Thanks for your help
Ludovic
Le 19/08/2011 14:20, Alan Boudreault a écrit :
> IIRC, the mapfiles in svn were only to test translation and loading. You can
> take a small standard mapfile you have and write it in xml. It should be very
> straighforward and you can use the svn mapfiles as example.
> Let me know if you need further help.
> Alan
> On August 19, 2011 07:42:17 am Ludovic Granjon wrote:
>> Hello
>> Someone is using mapfiles in xml?
>> I tried but it does not work, is there such a minimal mapfile in xml to
>> try? Is there a documentation ? I tried unsuccessfully
>> http://trac.osgeo.org/mapserver/browser/trunk/mapserver/xmlmapfile
>> Thanks
>> Ludovic
Type: text/xml
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110819/095fc007/mapfile-test_ludo.xml
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110819/095fc007/ludovic_granjon.vcf
